61 - 80 of 997 Posts
If I wish too still use my 3200 will the filter affect them or should they be connected ahead of the filter.
The filter is to prevent you from broadcasting your recordings to your neighbours and otherwise interfering with their service. It shouldn't affect your 3200 but the cost of installation should address any issues.
True
But?
When your renting your boxes it does make a difference.
HD PVR $25/month
SD Box $5/monthx3=$15/month
I believe the HD Boxes to rent are something like $10? $15? per month to rent?
The SD terminals do not support any networking features and manufacturers such as Cisco and Motorola aren't putting much R&D into SD terminals these days to bring updated features such as home networking as its becoming increasingly difficult to buy an SD television these days.
Remote tv manager support for 8642 pvr?
Any idea if this new update for the guide and whole home pvr will finally offer support for the remote tv manager for the 8642 pvr?
I just swapped back to the 8642 so I am ready for the update. I previously had the 8642 but then swapped to the 8300 to get the remote tv support.
Thanks in advance,
AK
yyzlhr: Even if they did come up with a solution for home networking with the old boxes (the E940 lists "multi-room DVR capabilities" in the product brief), without an MPEG2 HD decoder it wouldn't be able to play most of your recordings!
For those who tested it so far, does it make use of the Ethernet port on the back of the unit? Since it uses MOCA technology, you should be able to say, plug in the 8642 to your router and the coax network would bridge your network so you could connect your PS3 to the back of your 4642. If you have additional MOCA adapters, they are all suppose to be able to connect to it as well (as explained by the folks at CES who demonstrated MOCA technology) http://www.actiontec.com/products/product.php?pid=192
one question?
So whats the difference between this one (Ontario Whole Home PVR) and the one in Maritimes, other then the one in Ontario is cisco based and the one in the Maritimes is Motorola based?
Is one(Ontario vs Maritimes) features better then the other?
If so what are the diffrences?
Discussion starter · #68 ·
the filter goes @ the point of entry for the boxes you need min 1 hdpvr 8646 and up to 3 cisco 4642's per network if you have more than 4 cisco boxes will require a 2nd network to be set up each box on the network works ONLY in that network sa boxes will not work on these networks and will require a filter on them aswell so they can function properly!
Rogers is going to hear it from me if they want me to pay $50 for the Whole House PVR function. When I first got my 8642 and 4642 from Rogers, they told me that by getting those two units I was going to have that feature coming soon. I specifically was told at the time it would not be something I had to pay extra for. So this will get interesting.
I don't like the $50 whole home PVR fee. They're releasing the new guide sluggish and we have to pay a fee if just want to use our own PVR's we already have?
The $50 is to cover the cost of having to send a technician out to your home to install the filter that is required for the Whole Home PVR function to work.
If you don't like the fee, you can continue using the PVR functions on the TV set that the 8642HD is hooked up to. Rogers is in no way forcing you to pay the $50 for the extra feature.
I also suspect that the fee can be "waived" just like other installation fees if you deal with customer retention. It's purely speculation so don't quote me on that.
You need a Techniqion to help you... You will not be able to install filters by yourself..it might end up costing you more when you need to get something fixed that you broke
What filters do they need to install?
I'm assuming that the WHPVR function just uses a specific chunk of free spectrum that the remote units get their content on. The only reason I can see for needing a filter is that the chunk of spectrum they use will go back out onto the line through the bidirectional splitter that they have already installed.
I was under the impression that those already filtered/block some of the higher bands already. If that is not true then I can see why a filter is needed. Otherwise it is just a cash grab by Rogers, which of course is not surprising.
Mods, to reiterate another post earlier in this thead, it may be best to separate the posts about the new IPG and move them into a new thread, and keep this thread strictly about the Whole Home PVR feature.
Can anyone confirm will this system work on the 8300???
Little pissed off, that they have yet to fix my original problems with the 8300 and there "External PVR Expander" 1TB Seagate Drive....(where I lose recordings weekly) while its plugged in. This has been occurring for over a year, to the point where I don't use the (external drive) $200+ item I bought from Rogers.
P.S. this system worked flawlessly before the Firmware update 2 years ago.
Back to the matter at hand, can I get this system to work on my 8300 when its available here in London Ontario region? or will I need a 8642 model. AND if I get an 8642 model added to my house, can I still use the 8300 with it.
P.S. typical rogers to not fix something and go to something new, so people have to spend more!!!
The Whole Home PVR and the new IPG will not work on the 8300HD. I'd imagine you can keep using it, but it will continue to have the old IPG and the recorded shows cannot be viewed at the other setbox locations.
Feature Activation
When the tech comes to your home to install the filter. Does he have to activate the Whole Home PVR feature on each device? If not when they rollout this out wouldn’t your recordings start going out over the network, if the filter was not installed. Especially if you don’t subscribe to the Home Feature.
