421 - 440 of 478 Posts
No Power light on Bell 6400 receiver?
I purchased a used 6400-G2 and everything seems to work fine after activating on my account. I did notice there was no power LED on the front panel to show the receiver was on. Is this normal or is my 6400-G2 defective?
jdevlin, thanks for the quick reply. I forgot to mention it is the newer G2 version with the plastic case. It does not have a LED next to the power switch like in your diagram. It looks like there may be one to the right of the buttons...though it definitely is not on. Can someone confirm there's a power LED on this G2 6400? Thanks.
Yeah, it's been mentioned quite a few times here on this thread starting on post 171 onwards.
It looks like Bell's site only has the G1 diagram which I also found.
Thanks, again.
Edit. Here's a picture of the front.
Update:
I found a second 6400-G2 receiver with a working power LED.
Issue1:
Plugged USB drive from original 6131 to this 6400-G2
This second 6400-G2 does NOT play the content recorded from the original 6131.
Screen just goes black for about 5 seconds and returns back to contents menu.
It does record and play new content on the same drive.
The original 6131 does NOT play contents recorded from this 6400-G2
The first 6400-G2 (the one with the bad power LED) plays content recorded from the 6131
The 6131 also plays content recorded from the first 6400-G2
Both 6400 have the same firmware
It would seem original recorded content from 6131 are ok since 2 of 3 receivers can play them? Any ideas?
Issue 2:
The two 6400's guide cannot see the Animal Planet channel...even in 'All Channels' mode
I tried to reset the servers and synchronized from the bell site.
The 6131 still has the channel working when I check.
Bell External Hard Drive Facts part 2
Unfortunately thread "Bell External Hard Drive Facts" is closed so I could not post there.
Just been informed by Bell support that sharing EHD between 6131 receivers on same account is possible but drive must be reformatted. To me this is not sharing, one should be able to view recordings on either receiver.
Yet sharing same drive with computer is not possible because drive must be reformatted. Understood and accepted.
Imagine if all external drives used with computers required reformatting on each computer, it would defeat the purpose of external drive.
Fortunately for us sharing drives between computers is possible and works as advertised.
How silly of me to assume that sharing drive between Bell receivers would be same.
I am curious, has anyone been able to share EHD between Bell satellite receivers? If so, which receiver models?
thank you
This is 100% wrong.........
Once formatted for use on a 6xxx series Receiver, that drive CAN be used on any other 6xxx Receiver on the same account, just the same with the 9xxx series of Receivers.
As 57 says, the only limitation is swapping between a 6xxx & 9xxx, this is NOT possible as they work in different ways.
The 6xxx record directly to the EHD, while the 9xxx record to the Internal Drive and the EHD is used to 'archive' programs.
You just got a CSR at Bell, that did not know the facts.
Let me just put on my surprised face at this point.....lol
Bell 6400 audio issues
I just purchased a Bell 6400 receiver, the HDMI output is connected to a HD Video HDMI Extender, this unit replaced a Bell 6131 receiver.
I have video but no sound. I direct connected the 6400 to a TV in order to bypass the extender and the unit had both sound and video.
The extender audio supports uncompressed LPCM audio and compressed DTS-HD, Dolby true HD.
Can anyone help me with this audio problem.
Sounds like the issue is caused by the extender. Have you gone into the settings menu for the 6400 and tried different audio options. Something like PCM or DD, etc.
Perhaps the HDMI "handshake" between the TV and the box is not going properly through the extender. See the following FAQ on HDMI issues:
https://www.digitalhome.ca/forum/30-57s-home-theatre-faqs/71112-faq-hdmi-comments-issues.html
You state the audio compatibilities, but none of those is what the 6400 sends. It sends compressed PCM and Dolby Digital, although those are "lower" than the ones you mention. Do you have a link for the extender so we can see the specs, etc.
My 26 month old 6400 just died. no video out of the HDMI or RCA connection. Green power light flickers . unplugged for days and when plugged in, green power light immediately is on and still flickering. Doing a reset doesn't do a thing.
Capacitor(s) may have failed on the pwr supply or main board.
Not familiar with the model, but is quite common in all types of electronics.
That is probably what I would look for first.
6141 just failed
I've had this 6141 HD receiver for about 7 years and today it failed. It won't respond to any commands from the remote.
It's my "secondary" receiver that I watch hockey on. My primary receiver (6141) responds to commands from that remote.
Did the usual troubleshooting stuff and no dice.
Both the power and HD lights are on but nothing just "no Signal" on the TV.
Ordinarily I would suspect (and have before) that there is a cable problem but in that case the receiver at least responded to the remote.
So I'll be replacing it with a 6400.
My eHDD should be recognized no problem so I won't lose anything.
Sound out of synch on 6400 HD receiver
Hi: We are renting 3 HD receivers from Bell and this particular one (6400) has an annoying sound lag,which I can usually fix by disconnecting power for a few minutes,but seems to be getting worse.
Sometimes the guide showing the channelsis only showing up half way.
Is this receiver on it's way out?. Receiver is plugged straight into 35" Roku t.v via HDMI.Thanks,Huck
Another volume issue we noticed the other day,sound seems like it's under water.Powered off for about 10 minutes and all is good....sound lag seems to come and go,but more regular lately. No one else has this sound lag problem??
Bell 6400 won't recognize switch.This is a receiver bought used on Kijiji.The cable and switch is good because other receivers work fine on this LNB Dishpro Quad setup.The receiver will power on and off several times before finally turning on without signal.When a check switch is done it goes to 38 with nothing found.There is an 820uf Capacitor that is blown not to far from where the dish cable enters.Could this be the problem?
