21 - 40 of 58 Posts
Bell could also improve picture quality, which really went downhill when it increased compression and switched to 720p for most HD channels.
This what I noticed since the loss of 82 and everything moved over to 91, so maybe hang onto those SD channels
  • Pixelation and Jitter on HD Channels: particularly during live sports or action-heavy scenes, stuttering, and a "jittery" or choppy picture. possible sign of aggressive video compression.
  • Worse Picture Quality on HD than SD: despite their lower resolution,SD appear "cleaner" and more stable than their HD counterparts.
With the loss of signal on 82, 91 still has allot of SD channels left, in the neighbourhood of around 50 to 75. Clear up some of those channels and Bell would have some space for other channels
I doubt Bell has much excess capacity, but I'm not a satellite subscriber, so I can't check. It might help to read post 1 of this thread.
I use this site occasionally - https://channel.bell.ca/
It lists the unique satellite channels. My guess is that if you see any duplicates, they are actually remapped to the same transponder.
Thanks, for now we are just watching the SD channels and see how that goes, they appear to be OK and a bit better than the HD for now. I have 100% signal strength on some of the CTV channels in HD so strength is good. Thanks for the link. I have a 9400 receiver which is 9 years old, so maybe it is showing signs of issues as well.
I think maybe my LG TV is upscaling the picture as well from Bell, from 720 to HD content, I shut off HDMI Deep Color to 4K, maybe a little difference. When I stream the picture is perfect. So maybe I have a couple issues going on. Either way I swear it was better before the migration of the 2 satellites.
Yes, it was the original station resolution which was typically 1080i and it was the MPEG2 signal without much, if any, compression. The picture was much better. The irony was that the 6000 receivers used at the time had a poor quality graphics overlay chip that caused a lot of picture degradation. I had an adapter called a 169time that bypassed the graphics chip to delivered the original picture and it was very good. Then the picture quality started to deteriorate as compression was used to add extra HD channels. Just before Bell switched to MPEG4 they lost half a satellite and adopted a new scheme called adaptive compression which resulted in a lot of issues similar to those in post #25. 720p was adopted a bit later.
It's starting to look like Bell Satellite is slowly being switched to a combined IPTV and satellite service. I've even considered subscribing again and using the Bell Fibe app to watch TV. It wouldn't be much different than what I have now, probably more reliable on the IPTV side but it would cost more.
Yes, it was the original station resolution which was typically 1080i ...
Outside of OD, Bell has been 720P since I created the following FAQ 17+ years ago.
Thanks for the update. That sounds about right. I subscribed to Bell after the HD lineup was expanded in 2003, about 22 years ago. I may have the timeline a little off but I'm talking about 22 to 17 years ago. At the time, the HD lineup consisted of ten US network stations with HDNET, CITY-DT and a full time TMN HD added during that time. I started using the 169time in 2004, about 21 years ago. Bell was years away from having an HD PVR but the 169time allowed recording the unprocessed HD signal. Bell didn't have the capacity to do HD simsubs or otherwise process the signals and the US HD network feeds didn't have advertising during much of that time. It was some time before local stations had the equipment to insert advertising or overlays so it was a pure network feed.
It's hard to get TV Listings with Zap2it being gone.
You can still get the same TV Listings using a direct Gracenote link instead of Zap2it. You can even use the same user id and password.
Gracenote/Zap2it didn't always delete old channels. Plus I think I read that some SD channels were upgraded to HD in place, without assigning a new channel number. Other SD channels may be remapped to the HD channel.
21 - 40 of 58 Posts
