41 - 60 of 350 Posts
Just for future reference (in case I buy another new receiver), does Shaw Direct need to change some type of mode on new receivers so that they will work with the older dual-stacked LNB? If I had mentioned it when I first called to activate my DSR605, do you think things would have gone a bit smoother? I assumed this info would have been on my account.
Yes, tell them to chaage the v-code. It probably would have been a lot easier if you had said this from the start.
V-code is a code which defines what channel map you get, as well as the transponder RF map.
If you have an established account with that dish, the proper V-code should automatically be set to the receiver whem it was activated on that account.
If the dish is different than the dish on the accountn, then it may need a different V-code sent to it.
purchased the 605 from best buy
on sale with tv purchase
read the specs and it mentions that you do have the option to record
with an external hard drive with an esatta connection
tried this with no luck
called up shaw
clueless wonders there went on and on that the 605 was not capable
of any recordings
finally had someone look into what I was reading
turns out that the software for the pvr option on the 605 is still in the works
goes on to tell me not sure if and when
can anyone shed some light here on this software?
In post 35, SD 630 Support wrote in part:
Both #1 and #2 will set a recurring, program-based reminder. This means that when you're watching TV, each time an episode airs you will see the "!" sign appear in the top right-hand corner of the screen.
Because the system is now program-based (instead of time-based), recurring auto-tunes no longer make sense. A recurring auto-tune expects that you're using a VCR type device to record at a specific time
These are based on assumptions about viewer practice that are not correct.
For example, we want to watch Jeopardy every day on the Halifax channel. But we may not be sitting in front of the TV to see the 'reminder'. Suddenly we 'remember' that Jeopardy has not started, and we have now missed part of the program. Did not have this problem with the auto switch on our 505.
And it is not correct to assume that we want to use the timer to record on a VCR. We use the reminders to set up our viewing schedule.
To us , auto switch makes perfect sense. Some evenings there are several weekly recurring programs that we want to watch but they overlap. So we use time shifting to watch the programs in a specific order. Again, on the 505 this was easy. Now it is gone, and we have to do far more daily manual intervention.
Yes, some features of the 605 are nice, but in some ways it is a giant step backward.
John
found a bug in the 605 code
I have found a bug in the 605 that causes it to crash. Has anyone else found this one?
We have a custom favorites list called 'OURS'. It is quite large.
If I select the FAV to OURS, and hit GUIDE, I see our list.
Now I select FAV and set it to ALL Channels, hit Go Back (to save this setting), and now hit GUIDE again, the guide display contains overlapped characters and the 605 locks up and goes into auto reboot.
It looks like a memory management/memory overlap issue. I will call it in to tech support.
John
Yes, I've seen this problem (on a 630). You will notice that the bad display and reboot only occurs on the ALL channels list, not on the FAV. The scrambled display usually occurs when you scroll through the ALL list. Also, I have defined four or five (depends on whether NFL Sunday Ticket is on) active Favorites lists, and NEVER have had a problem switching between them - only when going back to the ALL list.
By the way, you can switch between lists while in the Guide by pushing the Options button, selecting the new list, and pushing the Return button. The Guide is repopulated (3 to 4 seconds delay) and displays the new list.
John
Yes, it happens all the time on my 630s.
It is just bad code that is not handling the guide data properly, the problem is who knows when it will be fixed...
The one good think is that it is easily repeatable so the coders have no reason not to be able to see it and resolve it.
Guide problem on HDDSR 605
The guide on the receiver seems to have frozen. I can see all of the program data up until 7:00 PM on 24 Jan. 2011, but after that, it just shows NO DATA. Today is 16 Jan. and the guide is supposed to show to at least 29 Jan. I have done a front panel reset, and it didn't fix it. I disconnected the power and coax for 2 minutes and it didn't fix it. I called Shaw and the tech had me go into the diagnostics and reset the guide information, and this didn't fix it either. It took me some time to convince the tech that this was actually happening. Has anyone else noticed this problem? Since Shaw doesn't seem to be able to help me, does anyone have a fix? I first noticed this problem on 11 Jan. and it has been stuck on 24 Jan. since then.
Correction ...
Re post # 50:
I have an error in the post I made in # 50. Yesterday, I noticed that the guide got corrupted after switching from one custom favorites list to another custom favorites list and scrolling through the entries. So, I was wrong to state that it only happens when switching back to the ALL channels list! Sorry.
Both machines (605 or 630) draw the same power whether on or off. The 605 should draw less than the 630 since there's no hard drive to spin - but I expect the difference is negligible.
Good luck on getting measurements.
OK actual wattage measurements via Kill-a-watt meter for the 605 is 15 watts on and 15 watts off !
The activations people said the recovery time from no power to powered up should be 6 minutes or less.
This unit will be put on a timer for sure !
dns2
Hi dns2,
If power is frequently being cut to the receiver, you may notice the following anomalies:
  • New Guide data is downloaded and processed each morning. If the unit is not connected, this will not occur until it is reconnected. Slower performance may be noticed while this is occurring.
  • Given the dependencies and logic built into the Guide backup, if the unit is frequently unplugged it will eventually stop backing up the Guide altogether. You will be reloading Guide from scratch each time the unit is plugged in.
  • As a result of the above, you'll have lots of missing program details. You'll be able to watch TV with 1 minute and access the Guide within ~6 minutes, but will probably have mostly "No Data" blocks until the Guide reloads.
  • The unit may lose authorization every few weeks, requiring a Refresh Signal to be sent to restore programming (this is because the receiver was not connected when updated keys were sent out)
Easiest thing to do would be to just use an old VCR to take the composite video output of the 605 and convert to coax out. Just leave the VCR set to 'Line In' and your setup would work exactly the same as before.
