SD Card Slot has stopped working.
1.7K views 3 replies 4 participants last post by  ExDilbert
#1 ·
This has happened before on my laptop.
For some reason it has stopped recognizing an SD Card when it is placed into the onboard slot reader. I can't recall what the fix was last time but know it was working within 2 months ago.
I have tried to uninstall / re-install the Toshiba drivers for it but that doesn't seem to fix it.
I also tried my USB SD Card Adapter but for some Windows 7 wants me to format the card without another option. If I were to do that I assume I'd lose all my pics on the card.
Any help is greatly appreciated, as always.
#2 ·
Sorry to not be much help but I've had a similar problem before. If you do find any info/fix please do post here so that I may try.
I was trying to read an SD card (well, it was actually a microSD card inside an SD card adapter) and windows kept telling me that it needed to be formatted as soon as I would put it in the reader. Good think my ready also has a microSD slot as I took it out of the adapter and it then worked correctly. I've also tried reading a regular SD card and that didn't work either so I don't think its the adapter. Might be the SD card port.
