Hi all,
I just wanted to relay my recent experience in purchasing a replacement lamp for my Panasonic PT-AE2000 from ProjectorLampSource.ca. They are a Canadian company and hence shipping and the price was $240 instead of $600 from Panasonic.ca - so everything looked good.
They say all over the site that its an OEM original bulb, however upon comparison, the original bulb has markings that say "made in japan" whereas the new bulb had no markings at all. Also of note, the housing is not OEM, its manufactured by a 3rd party - while it fits nicely, its devoid of warning labels but most importantly, it doesn't have this cardboard/paper-like cone/shroud around the bulb itself. While I didn't think that was important, it does eliminate excess light spill that will come out of the front air vents if you install the replacement bulb without one. I removed it from the original to use on the replacement but it did crack as it was old and brittle - but hardly worth $360. None of the replacement lamps online ever show this cone/shroud - does anyone know where I can get a replacement?
Most importantly, when I installed the new bulb, it was dim, dimmer than my outgoing 2500+hr original bulb. Within a few hours its started to flicker slightly. Upon removal, I noticed that the internal reflector coating within the glass bulb had flaked off and fallen within the bulb itself. I think that was what was causing the flicker. I might have just gotten a bad bulb and the replacement housings probably don't come with a cone/shroud. Anyone else with issues replacing a Panasonic PT-AE1000 through 4000 projector?
I called to get a replacement, but the 1-866 number is for sale only and could not help, the returns department is handled via online RMA request and I must wait for a reply from their returns department. Lets hope this goes smoothly, I'll update when I get a response.
I'd love to hear any other experiences. I hope in the end its not "you get what you paid for" of if its "too good to be true, it probably is..."
