I've had a problem for some time now where my PVR doesn't respond to commands from the remote control or the front panel buttons. It buffers the commands and will execute them eventually. It happens while trying to do just about anything with the unit, browse the guide, use fast forward/rewind functions, etc. I called Telus a couple times about it, the usual responce was reboot the box, which didn't do anything as far as a long term fix. They were going to replace the unit at one point but with the then rumour of new software with new features I figured I'd wait and see if the problem goes away with the upgrade. Unfortunately my area can't get the upgrade yet and Telus now says the delay is a known issue with no apparent fix and no estimate of when it will be fixed.
The tech the other night did some resync that wiped out my scheduled recordings, but doesn't seem to have done anything for fixing the problem.
I'd like to know if people that have had the delayed responce problem saw it go away with the upgrade with Media Room, or some other fix that might not be available to everyone.
