Saw this in a full page ad in the Globe the other day and it's also on the Rogers Website:
http://www.rogers.com/web/link/hispeedBrowseFlowDefaultPlans
Service: Download Speed / Upload Speed / Cap / $ (without bundling/discount)
Lite: 6 / 0.256 / 20 / $38.49
Express: 25 / 2 / 80 / $48.99
Extreme: 34 / 3 / 120 / $61.99
Extreme Plus: 45 / 4 / 150 / $71.99
Ultimate: 150 / 10 / 250 / $122.99
Ultimate Fibre: (only in select areas) 250 / 250 / 500 / *Check Availability
Note: Although the speeds are "up to", I have found that unless you're on the highest service, you typically get what you pay for and often more with SpeedBoost.
Note that the download speed (with SpeedBoost) exceeds the "up to" rate. I have found this to be the case most of the time (on Express). Of course SpeedBoost is only for the first short while and then you get your "max" for longer downloads.
Note: For some speeds and Caps you may also need to purchase/rent a DOCSIS3 modem. If you still have a DOCSIS2 modem, you may be "stuck" with a lower speed and/or cap.
