So I moved my Pvr from one room to another and now I get initialization failure when ever I power up the box.
I have 3 boxes 2 of which are fed through coaxial and one through Cad 5 directly to the network hub.
I moved the Cad5 one to a coaxial connection in another room and use a coaxial cable to the crt tv. At first I received no connection then after doing the power cycling problem solve. I got the the box to go through initialization but it fails every time.
As stated I have done the power cycling problem solve, the soft reset and changed all my cables and connectors including the one behind the cable plate and I still get the same result.
I can't really afford to pay the 100 dollars to have the tech come to my place to try to fix my problem and I was hoping someone on here can help me. Hopefully there is some simple trick I am missing.
Thank you
Ryan
Thank you
Ryan
