Markham: Woodbine & Major Mac
Hi guys,
I have a CM 4228 mounted on my roof and attached to a CM 7778. The cable (RG6) run is around 50 ft to my basement. Attached to the CM 7778 is a 4 way splitter which then connects to the following:
1 - Samsung LNS4696D LCD TV
2 - Hauppauge WinTV-HVR-1600 (SageTV PVR)
3 - Hauppauge WinTV-HVR-1600 (SageTV PVR)
4 - Hauppauge WinTV-HVR-1600 (SageTV PVR)
I have been having trouble with CBS (and sometimes I have issues with NBC & ABC). Once in awhile CBS will work but for the most part, I don't get any signal. Since spring is here I'd like to re-peak my antenna to hopefully get a stronger signal from CBS (as well as NBC & ABC).
Before I could re-peak my antenna, I wanted to measure my current signal strengths. To do this, I have found a tool from Hauppauge called WinTV Digital Signal Strength Monitor. Does anyone know if this tool is a reliable way to measure signal strengths? Below are the numbers I got from the tool.
Does this indicate that I need to point my antenna a little more to the west (I'm located at Woodbine & Major Mac - Markham) ?
Channel: SNR
2.1: 0 - 23
4.1: 0
5.1: 29
7.1: 0 - 17
9.1: 27
17.1: 27
23.1: 28
25.1: 27
29.1: 23
41.1: 25
44.1: 24
57.1: 18
64.1: 27
66.1: 23
http://hauppauge.lightpath.net/software/utils/wintv_sigmon.exe
Hi guys,
Channel: SNR
2.1: 0 - 23
4.1: 0
5.1: 29
7.1: 0 - 17
9.1: 27
17.1: 27
23.1: 28
25.1: 27
29.1: 23
41.1: 25
44.1: 24
57.1: 18
64.1: 27
66.1: 23
