Best option for playing .mkv video files in HD format on PS3
1 reading
9.6K views 10 replies 5 participants last post by  sleemo
#1 ·
What would be my best option to play .mkv video files in HD format on the PS3 besides the Bluray drive? streaming using Tversity, Media Center or install YDL 6.0 (play off of hard drive)?
I read that in all cases if you don't have a good peforming PC system the video will lag. Is this true? I have a P4 3GHz with 2 Gigs RAM.
Any suggestions?
#6 ·
What about .m2ts? I assume no transcoding needs to be performed in this case also. M2ts is the file extension in the Bluray format. Really VOB and m2ts are just the container, so no encoding is really peformed when the original file is converted from .mkv.
And will it do it in DD5.1?
#7 ·
With mkv2vob, the default is to create a vob file. You can make it an m2ts if you want. All the same thing when it comes to playing on the PS3. mkv2vob doesn't transcode mkv files. Basically just changes the container. The key though, is the DD5.1 is left intact. Actually, sometimes mkv2vob takes a little longer, if the mkv has DTS audio. It does the process of changing DTS to DD5.1, which the PS3 can play.
#8 ·
While I am no expert on the matter I was having some issues streaming my guilty pleasure (Anime Bleach) which is encoded as a H264 in a .avi (or so they say) from my PC to the PS3. I installed Tversity and did a few tweaks as per a thread I found and am outputting it to the PS3 in MPEG2 and it works like a charm. Looks great too, no loss of quality at all. Only odd thing was that the PS3 is reporting each file as 1.4GB and they are only 170MB each. Compression can't possibly be that good can it?
This may or may not have ANYTHING to do with your questions but I thought I'd share. :D
#11 ·
M2TS also works but you have to remove the "S" and name it with an M2T extension for the PS3 to see it. I've used tsMuxerGUI to convert MKV to M2TS when MKV2VOB was in it's earlier releases and if it had a problem doing the conversion. tsMuxerGUI ran faster on my slower machine back then, now it's about the same.
