Welcome here! PRINT THIS POST and follow these steps before you post in the OTA Forum:
Once you've researched the best options for your location and you are ready to find out where to purchase the OTA gear you need, the info in the following link will tell you where to find a vendor or installer:NOTE that if you don't follow these easy steps in your first OTA Forum posts your messages will likely be deleted and a message sent to you to follow the easy steps before posting again, so save yourself the trouble and do it right the first time. We love assisting newcomers but we also insist on respect for the time and efforts of our moderators and veteran members for their massive amount of existing information and advice contributed over the years. Once again, PRINT THIS POST and follow these steps before posting in the OTA Forum. Last edited by downbeat; 2011-12-06 at 12:36 AM. |
http://www.digitalhome.ca/forum/show...0&postcount=18 |
Welcome, it's really easy to figure out how to get started with OTA, because your location is the key.
Every part of Canada is represented by it's own thread in the OTA Forum's Reception Results sub-forum, so just check the titles carefully, find yours, and start reading! If you're in a big area like Vancouver, Montreal, or Toronto that is covered by several threads be sure to check all the thread names so that you use the correct one for your location. Follow all the steps in Post #1 of this thread. See, it's easy! |
I cannot stress this enough - your LOCATION is critical information in OTA Forum posts.
Enter your location (city/town, nearest major intersection) into your member user data so that it is always visible. As an example, look to the left of this post under my own user name to see my "Location:" |
Please do not quote an entire post. Rather, use only a short excerpt to help put your own message in context.
Additionally, please do not quote the post immediately preceding your own as it makes threads harder to read. Thanks for your understanding and your co-operation. |
Hello new members: Please be sure to follow all the instructions in Posts #1-#5 of this thread to make sure you're getting the best possible advice for your OTA reception questions.
Thanks and happy viewing! Bonjour aux nouveaux membres : Veuillez suivre les directives au lien suivant … http://www.digitalhome.ca/forum/showthread.php?t=140196 … avant de poster dans notre forum OTA en français. Merci! |
