#1 | ||
1. What does OTA mean?
It stands for Over The Air television reception, as has been available free-of-charge in Canada since the early 1950s using antennas for reception. OTA is not to be confused with FTA, which is a form of satellite TV reception using entirely different gear.2. Why are we switching from analogue to digital TV? Analogue TV (also known as NTSC) is the original television standard in North America and it has served well for many decades but it is prone to many different kinds of interference that can make viewing troublesome for consumers. The new digital standard called ATSC (also known as DTV, for Digital Television) eliminates almost all of that interference, as illustrated in this split-screen video made by recneps77:
In an ongoing poll of DHC OTA users, the great majority have paid less than $500 Canadian for all the OTA gear they required. Less than 1% paid more than $1,000. Some have canceled some or all of their satellite or cable programming, so their OTA equipment will pay for itself in savings over time. There are no direct costs or fees to the consumer for OTA programming.4. Are there OTA stations in my area? The OTA Forum has a sub-forum called Reception Results which features a thread for every section of Canada. Read through the thread for your own area and if necessary the surrounding area(s) to see what DHCers have already reported. A vast amount of experience and trial & error has gone into those threads, so please read through yours from the beginning. See Post #10 in this OTA FAQ to learn how to use a variety of online tools for best aiming of your OTA antenna for the stations in your area.5. Will I get stations from more than one city? TV antennas need to be pointed at the broadcast antenna, so if the cities are fairly well lined up in one direction, aim an antenna and enjoy. If you are fairly evenly between two locations there are antennas that receive front and back simultaneously. If the cities are wide apart, mount the antenna on a rotor. You can program the rotor's remote control to turn the antenna into proper position, which will usually take less than 30 seconds. Some DHCers have used 2 or more antennas aimed in different directions rather than a rotor. See Post #16 in this FAQ for info on how to combine 2 or more antennas.6. What if the stations are far away? TV signals typically start to drop off in strength as they travel about 120 to 180 km outwards from the broadcast antenna, so reception in those deep fringe and deepest fringe areas requires special antennas, gear, and installation techniques as you reach or exceed the higher distances. Expert help is available to you by discussing your situation in the Reception Results thread for your area.7. Will my TV get the Digital OTA stations? Check to see that it has an ATSC Tuner. Older TVs and unfortunately some brand new HDTVs still have NTSC-only tuners, which will not receive DTV stations and will be obsolete after August 31, 2011. Until that date a consumer should have an NTSC and ATSC tuner so that they can get existing analogue and new digital stations. See Post #17 in this FAQ for more detail on ATSC tuners found in set top boxes, HDTVs, and other equipment.8. Okay, which antenna do I need? The DHC OTA Forum contains detailed threads about different OTA antenna brands and models. See also Post #3 in this FAQ for antenna buying tips, and also be sure to download the Antenna Decision Chart (PDF). You will likely need to do some reading in the OTA Forum to understand the rankings and other criteria in the chart. Keep in mind that just because a competing-brand antenna looks a lot like a leading brand antenna does not mean that it performs the same - there can be significant performance differences. Stick to our advice on brand and model recommendations and you will not go wrong! If its not on the chart, don't buy it. Also see Post #3 in this FAQ for essential Antenna buying and planning tips.9. I'm pretty handy with tools. Can I build my own antenna? Absolutely yes, and in Post #12 of this FAQ you'll find info on best plans, techniques, materials, and other great info for Do It Yourselfers, including how to use computer modeling software for antenna design. The DHC OTA Forum is the one and only home of the Gray-Hoverman do-it-yourself antenna project, which has created a home built super antenna for UHF reception.10. Some new antennas look the same as my grandfather's old one! Aren't they old fashioned? No, TV antenna technology is essentially the same as it has been for several decades because the laws of electromagnetism and physics apply equally now as they did then. Today some manufacturers are finding clever ways to cram antennas into small form factors, but unfortunately due to those laws of nature the antenna's performance drops the more they try that. Manufacturers now have modern materials to work with so the construction of their products seems to be more durable, but antennas have often lasted more than 20 years. Since TV antennas have been around so long, there is already a large body of real world knowledge about antenna designs and capabilities. See Post #5 in this FAQ for an explanation of how TV antennas actually work.11. Which other OTA equipment will I need? There may be conditions affecting your reception that require specific equipment, such as preamps, attenuators, distribution amplifiers, splitters, combiners, a tower, etc. If you try such equipment without proper knowledge or guidance you could damage your TV and other equipment. The OTA Forum is the right place to ask the experts. See Post #14 in this FAQ for further info.12. Aren't Satellite and Cable TV better than OTA TV? For specialty channels and pay-per-view movies and events, Satellite or Cable TV are needed because such channels as TSN and Discovery HD are not broadcast OTA. However, if you want regular, local programming, OTA is free of charge or fee to the consumer. The only cost you will pay is for the gear itself and any taxes on it.13. Does Digital OTA TV have an On Screen Guide? Yes, the ATSC standard incorporates a data standard called PSIP, which contains program, channel, time, and other data for the ATSC tuner to display. There are also several Third Party program guides available, such as TVGOS, TitanTV, Schedules Direct, and others. See this thread about OTA On-Screen & Third Party Electronic Program Guides.14. Why is everything here named in letters that I don't understand? See the DHC FAQ regarding Acronyms & Definitions15. What does DX mean? Here in the OTA forum we sometimes use the term DX, which means Dial Crossing. DXing has been a hobby of enthusiasts going back to the early days of radio and now of television. DXers enjoy scanning broadcast frequencies in search of unusual or long distance signals, such as during odd weather conditions. Thus, DXers are very knowledgeable about high quality equipment and the techniques needed. Many TV DXers are also ham radio enthusiasts.16. Isn't all this OTA stuff illegal, like satellite piracy? NO! OTA television reception is the original form of television broadcasting and is 100% legal as always. See Post #13 in this FAQ for further information about the legality of OTA.17. Is all this great OTA info free? This web site, www.digitalhome.ca, is a private business run by Hugh. It cannot survive on bread alone. Please register as a member at our site, at no cost to you. Last edited by stampeder; 2009-12-25 at 04:16 PM. |
#2 | ||
Why can't there be one simple OTA setup for everyone?
Listing a bunch of stations is easy but not very realistic or helpful to readers because reception conditions are very local, even between houses on the same street if one is up high and the other is quite a ways downhill. The approach at this web site is to provide information that is extremely local to a person's location. We use Reception Results threads for every part of Canada rather than general lists that usually are not satisfactory. Over about five years we have accumulated Reception Results from people living all across Canada, so now the general expectation of what a person can receive has become clear for most major centres and populated areas. Unfortunately in some areas on the fringe of reception from DTV stations we just don't have very many user experiences to rely on. With time this will change, and we are grateful for the pioneers out there.Will I be able to just "set and forget" my OTA gear? If I need to change it can I get help with keeping my OTA system at its best? Yes to both questions, but in all honesty TV stations change over time, and we do our best to keep our readers up to date. With members who are station employees and in other broadcasting positions we often get the news before anyone else does. Last edited by stampeder; 2009-07-11 at 11:31 AM. |
Do you have some antenna buying tips?
Antennas are designed along well known electromagnetic principles that predate HD, SD, DTV, etc. by almost a half century. Any vendor that claims that a particular antenna model is "better for HD" etc. etc. is full of it. Don't pay attention to that misleading sales & marketing nonsense. The original Channel Master 4228, for instance, is one of the highest rated UHF antennas out there today for all analogue and digital reception, yet its design is about 30 years old! Channel Master has replaced it with the 4228HD, which may mislead people into believing that it is better for HD when in fact independent research proves that it is weaker than the original that it replaced.Is there a warning list of OTA stuff that I should never buy? Yes, there is a humourous thread called Wacky, Tacky OTA Gear (What NOT To Buy!) that is well worth reading to help you avoid wasting your money on junk and OTA gear NOT to buy. Avoid gimmic antennas such as the ill-conceived Terk 55, the fraudulent Xium Air, or the ones that promise to turn your household AC wiring or aluminum eaves troughs into a TV antenna. Additionally, the OTA Clone & Coat Hanger Antennas - Avoid Most Of Them thread warns of cheap "clone" antennas that may look like high performance models but are usually poor performers.Can I just go to my local consumer electronics store for OTA stuff? Yes, it is possible that some of those stores may have some OTA equipment and OTA-savvy knowledgeable staff, but as of early 2009 in Canada it seems that retail staffers in general are not well briefed on Digital OTA. You can read through the Popularizing OTA HDTV In Canada thread to get a better understanding of the situation. For this reason we recommend dedicated, knowledgeable OTA vendors for your parts, sales, service, and installations.Is it okay to use an old antenna? Oxidation may be a problem on many old antennas if it is causing welded or soldered joints to fail. If your antenna is still solidly constructed you are fine to clean it with steel wool. I would use something like an SOS or Jet pad for that. Clean the feed points too (where the balun is connected) and replace the old wingnuts or screws with new ones.Can I put up my own antenna? Absolutely, and Post #21 of this FAQ gives a variety of useful tips and links to discussion threads about important antenna installation topics. For those who do not wish to put up their own antenna and OTA gear, experienced, professional installers can be found in almost any part of Canada and the United States.An Overview of Various Antenna Types As you read through your printed-out Antenna Chart, here is further info on the most highly regarded consumer antennas. If you cannot locate one for purchase, try to find the next highest one rated on the Antenna Chart: Last edited by stampeder; 2010-05-20 at 12:59 PM. |
#4 | ||
Let's face it, for Canadian consumers the choice of TV antennas usually comes down to a short list of four main brands that give the best performance for the money and especially in Canada's wide geographic areas and cold, cold winters/hot, hot summers.
On another web site I read a commentary in which a consumer said something like: Quote:
My personal opinion is that for almost any customary consumer usage in Canada I would be very surprised if you cannot find a satisfactory antenna from one of the four main manufacturers. Most of the TV antenna professionals and experienced hobbyists in Canada have personal experience with them and can easily get parts and accessories for them. Buying from Canadian suppliers is also good for our small business economy too. Main Consumer Grade Antenna Brands in Canada and the U.S.A. Wade-Delhi and Winegard are veteran North American companies that manufacture their own antennas and supply other companies with product for commercial rebranding under such names as AntennaCraft, RCA, Zenith, Philips-Magnavox, Terk, Radio Shack, and others. Both companies offer wide ranges of antennas, amps, and related OTA gear.Professional, CATV, Military, and Research (Highest Quality) Wade's professional division (TACO), along with Blonder Tongue, cater to the highest end of the professional OTA market, in which CATV Head End installations and Research are the main usage. Products like precision cut single channel yagis, log periodic antennas, and giant parabolic reflectors are therefore built to exacting standards and in fact are often not useful to average consumers wanting basic UHF/VHF/FM antennas due to their specific designs for only certain uses. It is possible to find useful consumer-grade antennas from them, but they'll be very expensive. Each manufacturer offers a wide range of professional grade OTA antennas, amps, and related OTA gear.International Antennas Keep in mind that due to smaller broadcast areas across Europe and Asia, the antenna manufacturers give less emphasis to the kind of fringe and deep fringe conditions that we take for granted in North America, but more emphasis on side and rear signal rejection due to greater competing station density over there. Certain UHF antennas from Europe and Asia are unusable here due to some frequency differences. VHF antennas from Europe are not suitable for Canada, usually due to polarity differences. Last edited by stampeder; 2009-04-19 at 04:25 PM. |
#5 | ||
In the passing age of Analogue TV reception, indoor antennas have suffered a myriad of reception problems, and more money has probably been wasted on them over the years than on any other type of OTA equipment. In fact, the Consumer Electronics Association, which provides general ratings of all standard antennas, continues to refuse to rate indoor antennas.
The transition to Digital TV is helping to overcome many of the reception difficulties faced by indoor antennas, but not all such problems can be easily cured. For this reason, they should be considered last or only if an outdoor antenna is not a possibility. Zenith Silver Sensor & Clones The Zenith ZHDTV1Z Silver Sensor indoor antenna is considered the benchmark design for indoor UHF ATSC antennas.Rabbit Ears Antennas Mounted In Attics Analogue TV reception with attic-mounted antennas has traditionally been haphazard and unsatisfactory for most people due to problems with ghosting and other interference caused by reflection of signals off of metal hardware such as sheet metal flashing, electrical boxes, aluminum siding, etc. Last edited by stampeder; 2009-06-16 at 01:34 PM. |
#6 | ||
First a little bit of electronics theory to clarify some concepts
Hopefully this will not leave you glassy-eyed or confused, so you can skip this part if you like and go right to the next post in the OTA Knowledge Base & FAQ.Why do some stations broadcast in the VHF band while others are in the UHF band? Usually a station's assigned channel is a matter of it being available in a given area so that it will not interfere with another station on the same channel in a different area. VHF channels were the original ones, but over the decades channels in the UHF band were assigned by Industry Canada (and the FCC in the U.S.A.) as demand for channels by broadcasters increased.How does a bowtie reflector antenna work? What does a reflector on an antenna do? Reflector meshes or rods cause an antenna to be "directional" by causing signal strength from behind to be lessened while simultaneously causing the gain at the front of the antenna to increase by the same amount. The reception pattern thus becomes very forward-biased, which is rated as its Front-to-Back ratio (FB). The higher the FB, the more directional the antenna is. Last edited by stampeder; 2009-06-21 at 12:30 AM. |
#7 | ||
This illustration gives an overview of the Digital OTA broadcast process from a TV station's cameraman all the way to a typical 2008 full OTA home installation with outdoor antenna (skipping tons of technical detail, of course!): Quote:
Maybe, maybe not, (See Post #2 in the OTA Forum Knowledge Base & FAQ) but the best way to find out is to read through the Reception Results thread for your area to see how others have done. Last edited by stampeder; 2009-01-30 at 02:40 PM. |
I go way back with Over The Air (OTA) television. When I was a kid my dad was doing TV and Antenna repair/service in the 1950s as a moonlight job while he was an avionics guy in the Royal Canadian Air Force so I grew up all across Canada as Dad got transferred around. Then through the '60s and 70s he worked in educational television program production in Ontario. I worked with my dad in the TV program production world and doing CATV installations in schools and large buildings.
OTA is a hobby of mine that had gone away until the promise of ATSC DTV (Digital Television) brought things right back to life again in the late 1990s. When I joined the Digital Home web site, finding folks there who shared my OTA interest was a bit difficult although there certainly were very knowledgeable OTA folks, but besides them I was struck with how few people seemed to understand the past, present, and future of OTA. I had been lurking in several U.S. OTA forums and had been actively posting at Home Theater Spot's Antenna Spot for awhile, where I got to know quite a bit about today's ATSC environment as it was unfolding in the U.S. a few years ahead of the Canadian OTA scene. I realized that much of what was known about analog OTA was applicable to digital OTA too, but there are some rather key differences. Hugh, the Digital Home site owner, was very supportive and helpful about starting a forum here specializing in OTA, and so it is my pleasure to have created and moderated the Digital Home Canada OTA Forum to share such info. It is my hobby, and so you will find a spirit of friendly good-fellowship there. We get some veteran OTA professionals and hobbyists there who chip in and offer their expertise, and some of them have been posting at Digital Home for several years. Overwhelmingly, though, the visitors are newcomers to OTA and generally too young to remember when antennas were a necessity and cable (and especially satellite) TV were really new or unheard of. Thus, my philosophy regarding the OTA Forum is that it is a Knowledge Base, so that people setting up or adjusting their gear for the first time or the fiftieth time can have some of the guesswork reduced or eliminated no matter what level of knowledge the reader arrives with. I delight in reading the first results reports from newcomers, and it is pleasant when the more experienced readers offer advice and assistance to fix problems or address concerns. To me the advice must also come in the form of warnings, "gotchas", and other tips. We keep in mind that there are no stupid questions and no technical OTA issues too small to discuss. There is only one way to do things right, and that is to do them the right way. Cordially disagreeing with me is quite alright, by the way. Here is my personal web page if you wish to find out a bit more about me: http://www.user.dccnet.com/jonleblanc/ Last edited by stampeder; 2009-06-08 at 11:03 AM. |
#9 |
Digital Home Founder
Nice work stampeder. It's really nice when members take the time to help others.
On behalf of DHC and all members, thank-you! |
#10 | |||||||
WARNING: If you have not already read Post #2 in the OTA FAQ please do so now. Even with the best prediction tools as listed below, your results may vary!
Using TV Fool to Determine Your Available OTA Stations in Canada A fellow named Andy Lee has integrated the U.S.'s FCC database information and Google Earth to create some nice visual representations of signal strength, and transmitter locations. As of October, 2009, Industry Canada database information has been added, making the TVFool experience much more accurate for Canadians. Follow these step-by-step Instructions:Using SJM's site: Using the FCC's Online Mapping Engine: You can go to the FCC's OTA maps site and punch in your Canadian postal code to see if any U.S. stations will reach your area. When it shows the stations you can click on one to see a direct line from your location to it: http://www.fcc.gov/mb/engineering/maps/Using Google Earth and/or Google Maps: Using the Rabbit Ears site: Using the Antennapoint site: Antennapoint provides a quick set of aiming points for U.S. DTV stations nearest you:Using the Earth Tools site: Using the Touratel site: There are topological maps online here:Determining Your Magnetic Declination in Canada: Don't trust compass bearings until you've factored in the magnetic declination for your location: Last edited by stampeder; 2009-10-27 at 01:26 PM. |
#11 |
Industry Canada database (all present and future Canadian OTA TV stations, including U.S. Border Zone station data)
http://www.user.dccnet.com/jonleblan...a_TV_Stations/FCC TV Database Query (all present and future U.S. OTA TV stations, including Canadian Border Zone station data): http://www.fcc.gov/fcc-bin/audio/tvq.html Last edited by stampeder; 2010-08-06 at 02:46 AM. |
#12 |
Yes, you can build your own TV antenna, and the very best of the designs are the Gray-Hoverman and the M4, both available in several variants for different reception requirements. Our Antenna Research & Development sub-forum contains a wide variety of discussions on almost every aspect of building a TV antenna. There are several threads stickied to the top of the listings, and each contains detailed construction plans for several GH and M4 variants. Have fun!
Some examples of Gray-Hoverman variants: An example of an M4 antenna: Last edited by stampeder; 2009-09-06 at 12:39 PM. |
#13 | ||||
TV broadcasting in Canada has been done Over The Air since the 1950s. Cable and Satellite came along later as supersets of that. OTA is 100% legal and always has been. By installing antennas for clients you are not exposing yourself or your clients to any legal consequences arising from their receiving Digital OTA TV. Antenna installers have been doing it for almost 60 years in Canada and it is completely safe from a legal perspective regarding their clients' reception of broadcasts.
#14 | |
Overview
In a perfect OTA world, a consumer would just connect a small antenna to their HDTV and proceed to pick up all the wonderful DTV programming available in their area. In reality there may be cases in which the OTA gear needs to be of a certain quality and performance capability to bring in distant or dispersed signals. Boosting the antenna's output is often the answer, so preamplifiers and signal amplifiers are commonly available for OTA users to accomplish that task. Not all OTA amplifiers are alike. Each type of amplifier has separate roles to play, and they should not be confused with eachother. In some cases the signal from the antenna might be too strong, so there are ways to lower that signal while keeping the quality of the signal high.Key Concepts:
OTA Amplifiers - A Quick Introduction
OTA Preamps - a Pleasure To Compare Preamps are used for taking in your antenna's signal as close as possible up the mast nearest the antenna and amplifying it in very specific ways to allow the signal to travel strongly down a cable to your tuner. Don't assume that any old TV/CATV amplifier will do, it has to be a specifically designed antenna preamp.Professonal Signal Amplifiers, Drop Amplifiers, and Distribution Amplifiers - Reliable and Known Performance If a preamplifier is not sufficient to provide a strong enough signal to all your TVs, FM radio tuners, PVRs, and other receivers below the antenna, it is time to put in an amplifier below the preamplifier. Having said that, there are times and places in which a very high gain/low noise preamplifier can do the job itself, but seldom the other way around. A signal amplifier is not therefore a lesser thing than a preamplifier; it has 2 benefits: some models can be purchased with several outputs, some with adjustable input and outputs, and in all signal amplifiers are generally capable of handling high power input signals and spreading them evenly across one or more outputs. Other more specialized signal amplifiers allow blending of such things as the OTA signal with CATV, Satellite, etc.The Sorry State of Common, Store-Bought Signal Amplifiers Now contrast that with the sorry state of Signal and Drop amplifiers that are sold blister-packed, far and wide, in consumer electronics and department stores. Apart from their Raw Gain figures, none of the critical specifications such as Noise, Return Loss, and others are listed on the packaging nor even on the web sites of the companies shown on the labels. Indeed, it is often impossible to tell whether any company electronics engineer would exist to answer questions about those specs.Attenuators If your chosen amplifier's output is too high, causing trouble with TV reception, it is possible to either adjust a distribution amp's output level downwards on some models or put an attenuator downstream of the amp. Attenuators are for purposely lowering the signal strength in a cable run in order to prevent such symptoms as signal overload, in which a TV or FM Radio tuner cannot cope with too strong a signal. Its not good to try to fill a balloon with a fire hose...FiltersYou can get them in a wide variety of attenuation levels from a good antenna store, but I also found them in 6db strength (only) at The Source for a low price, where they are sold under the Nexxtech brand. They look like simple F-type coax couplers, but a little bit longer. They are handy to have around if you are trying out a new preamp/amp. Adjustable attenuators are also avaliable but are more expensive. Reasonably priced adjustable attenuators can be found on the Antennas Direct website. Sometimes there are cases in which we might wish to raise or lower the signal on an entire band, such as when joining two antennas to use the UHF band from both of them but using only the VHF band from one of them. Perhaps we might wish to just raise or lower the signal on specific channels in relation to the other channels, rather than on all of them. For this we use filters. Filters cannot amplify; they only attenuate. Last edited by stampeder; 2009-05-24 at 01:33 PM. |
#15 | ||
Sub-Channels
In layman's terms:
This is a feature of the ATSC standard for use during the analogue-to-digital transition that allows broadcast stations to telecast on a newly assigned DTV channel but "trick" the receiver at your home into displaying a channel number that corresponds to the original analogue channel or any other unused channel they please. Last edited by stampeder; 2009-06-15 at 02:19 PM. |
| Bookmarks |
| Tags |
| antenna, atsc, chart, faq, hdtv, knowledge base, ntsc, ota, stampeder |
| Thread Tools | Search this Thread |
