41 - 42 of 42 Posts
Go to setup, function setup, network, and is DHCP set to on?
Mac address filter set to off, network standy is off too.
What are your router settings? If you can plug any other computer through ethernet and connect to the internet with ease, than the 6295 should too. If a computer can't, than recheck your router settings.
Yamaha HTR 6295B Inteernet Radio "Access Error"
Costa
Thanks very much for your response. I've the same settings as you've suggested. I've two ethernet coming out from that wirelessbridge (Netgear WGPS606). One goes to my Sony TV for browsing You Tube and I can access You Tube on my TV without any issue. The second ethernet cable is connected to the Yamaha HTR Reciever. However, I get that "Access Error" message. Also, I can see the HTR6295 through my laptop under "View Network and Computers and Devices". Not only that I can access the songs (media files) that are on my laptop through the same Yamaha receiver. I think it means that the receiver is connected to the network. (Please correct me if I'm wrong). I don't know why I'm still getting that "Access Error". What should I check in the router settings?
41 - 42 of 42 Posts
