1 - 8 of 8 Posts
I recently bought a yamaha RX-V663BL recciever with 5 speakers and a sub. I have a ps3 hooked up as my bluray player connected by a hdmi cable. My problem is when I play a Bluray..Batman begins..I hit select on my ps3 controller and it says Doldy digital 5.1 as the audio...not dolby true hd. I have my audio settings on my ps3 set to hdmi and auto select and my blu-ray output settings set to lpcm. My reciever lights up pcm when the blu-ray is played. Im wondering why when I hit select it doesn't say dolby true hd? Any help would be appreciated.
Why not try with a disc that actually contains a Dolby TrueHD sound track?
when I play a DVD..Batman begins
jlet beat me to it, so unless that is a typo and it's supposed to be Blu-Ray, that might be your problem...
Let's assume all your connections are set up properly.
When you start up your Blu-Ray disc, do you select TrueHD in the audio options in the movie menu? Sometimes it defaults to Dolby Digital; you might have to manually select TrueHD.
I believe the reason is that your PS3 is doing the decoding of the TrueHD signal and sending it to the receiver as uncompressed multichannel PCM sound. The receiver won't indicate that it's getting TrueHD unless it is the device decoding it.
I don't think that's the issue. He's saying that the PS3 info bar is displaying DD5.1 instead of TrueHD.
I have found with several films that I have to hit the audio button on my PS3 remote and cycle through to the TrueHD audio - it often defaults to DD5.1 (Blade Runner as an example).
1 - 8 of 8 Posts
