1 - 4 of 4 Posts
Hi,
I have an XM tuner built-in to my car and a subscription. I wanted to try listening to XM at home with my receiver (Pioneer VSX-918V). Is this all I need to get going: http://****************Audiovox-XHD2H1-Tuner-21-Inch-Cable/dp/B003H3HFQE/
Also can I use my current car subscription or will I have to buy a new one to listen at home? If I have to buy a new one, is there a discount?
Thanks!
- Yes you will need a separate account to listen inside the house on your receiver.
- Your link is not working for me, so I can't tell what it is.
- I have XM radio in my vehicle but not "Built-in" its a separate device (docking station) that I can unplug and plug into the home kit. That is the only way to make it work on one subscription to my knowledge.
Good Luck
A second subscription will come at a discount price, $7.99 IIRC.
Discussion Starter · #4 ·
Thanks for the replies. The accessory I was going to buy was the Audiovox XM XHD2H1 (product B003H3HFQE on amazon.ca).
1 - 4 of 4 Posts
