1 - 3 of 3 Posts
I recently got Internet cable including the basic channel programming. So far I have the cable connected to an old standard TV, which includes a buit-in electronic tuner. At the moment I'm able to watch the channels which I been subscribed only through the TV tuner. However this tuner does not have a guide, like the guides on the satellite receivers.
My questions are as follows:
I would like the Interactive Programming Guide which I believe it's only available though using their cable box, like a [guide] button on the remote control - right? I'm not sure if that is so.
-If I find a used box in a thirft store, or try to buy a refurbish unit, or get one from someone... would the Interactive Guide work, and does it have to be a particular model?
-Would I need to notify Rogers in order to activated or validated the box in order to start using it, or can I just find one and then go home and plug it?
Thank you in advance for your input.
You might want to take the time to do a search, these subjects have typically been covered heavily previously. I'm sure 57 will tell you the same but he might be kind enough to point you to a thread or two. I'm not. :)
1. The Roger IPG is only available if you have a STB.
2. There is TVGOS available on some TVs - search this site for that term - doesn't work well.
3. Here's the thread on purchasing a used STB.
http://www.digitalhome.ca/forum/showthread.php?t=35032
4. Yes, you need to have Rogers activate it and you need to pay for digital service. You can't just plug it in
Please see the following post, useful for those new to the forum - FAQs, Search Tips, Optimization, etc:
1 - 3 of 3 Posts
