Building an HTPC has long been a challenge I wanted to tackle. I wanted a system that would be able to watch/record cable, play Blu-rays and also play some games. My build:
Intel Core Duo CPU
ASUS P5Q-E
4 Gb DDR2-800
EVGA Gtx 260 Core 216
LG GBW-H20L BD-R
Enermax 625W
1 Tb Samsung Spinpoint F1 HD103UJ
Auzentech X-Fi Home Theater
Hauppauge PVR-150
Keyboard Logitech diNovo mini
Logitech Harmony One remote
Monitor/TV Samsung LN-T4761F
Stereo Amplifier: Yamaha RXV-1600 (HDMI 1.2 only)
BD software Software: PowerDVD 9 Ultra (recently upgraded to 10 Ultra)
Initially the build had Vista Ultimate in it. Everything worked fine. My video went through the X-Fi and to my TV. Since my Yamaha doesn't have HDMI 1.3, I was using SPDIF out for the sound. This made things cumbersome switching to DD Live for video games and back again for everything else. Also, the Samsung Auto-Motion Plus settings looked better when I moved out of PC mode, but then that required me resizing my desktop to less than 1920X1020, but that all worked into a routine at least.
Enter Windows 7. With all the anti-Vista hype, I purchased Windows 7 Pro 32 bit. Since then, I have successively had to contend with two things: 1: when playing a Blu-ray, the movie will stutter with a corresponding CPU spike, with the audio continuing before the picture jumps forward again. And 2: the dreaded black screen of death.
For 1: I've disabled everything. Viruses, taskbar programs, Windows Update. Doesn't work. I run ReClock in the background, didn't seem to do anything. I unchecked the certificate thing that I read about in an AVS forum. Didn't work. What would cause CPU spikes with my new system?
For 2:
I've tried the PrevX fix. Didn't work.
Sometimes my IR blaster registered as faulty (I understand that the PVR-150 isn't fully compatible with Win7), so I disable it to reboot. That doesn't work.
I tried searching for viruses (Microsoft Security Essentials), and I've done the scandisk fix. Doesn't work.
However, sometimes, it does work. I don't know what I do, but it does. The last thing I did recently from the last time it did work was update the nVidia drivers from 197.45 to 257.21. Now, nothing seems to work.
Screw it. After all the money I paid, I went out and bought a Samsung BD-C6500 for $230 at Future Shop. I guess I'll go and try a system restore later and see what happens. Until then, I'm going to watch BBC Life in the way I suppose it should be seen.
Any help or insight will be appreciated.
Intel Core Duo CPU
ASUS P5Q-E
4 Gb DDR2-800
LG GBW-H20L BD-R
Enermax 625W
Hauppauge PVR-150
For 2:
