1 - 5 of 5 Posts
To enter "GodMode," create a new folder on the desktop and then rename the folder to the following:
GodMode.{ED7BA470-8E54-465E-825C-99712043E01C}
The folder will have a unique icon and inside the folder you'll have access to virtually every configurable option in Windows 7.
Very neat
Really don't know what you are asking. I renamed my folder and it worked for me.
There are actually a number of "Godmodes." Windows 7 Themes: Enable Secret Godmode
I find that Windows search is actually more powerful in practice. Just open the Start Menu and type something. For example, typing "mouse" finds all Start Menu items, Control Panel items, folders and files that contain the string "mouse." It can be used to find specific files on disk, as well. Wild cards, such as "*" can be used. For example "net*.exe" finds all exe files that start with the word "net".
1 - 5 of 5 Posts
