1 - 2 of 2 Posts
We bought our Sony about 2 years ago and have the chance to buy a Sanus Low Profile Flat Panel TV Wall Mount(Model# VMPL2S-03) for a really great price.
Will the wall mount work with the tv, or would I also have to purchase the adapter?
Thanks in advance,
· Member #1
Most mounts that are able to handle a 46" television should work since they are pretty standardized.
To be sure, read your TV manual. It will tell you what type of mount you need for your television. Cross reference that with the Sanus mount and you'll have your answer.
1 - 2 of 2 Posts
