1 - 6 of 6 Posts
I switched from a HDbox to the PVR box today. I always watch CTVHD news here in Vancouver at 6pm.
I now see a white line at the top of the screen that flickers,
I never had that with the HD box.
Are there settings in the box to get rid of the white flickering line that runs across the top of the screen?
Nope. I switched the receivers and voila line at the top. I only see it on 2 channels in the HD channels. All the same inputs etc.
Thanks for the link.
Also, see what the current settings are for overscan on your TV. It's very rare to see VBI if you're not set for 0% overscan. It usually happens on 4:3 upconverts but sometimes on true HD as well. Sometimes you can see a line on the right side as well, as per the FAQ. As mentioned by Dr.Dave, some settings on the STB may also be different, or simply a different STB.
Discussion Starter · #6 ·
@stationg, it's possible your TV processes 1080i and 720p signals differently. Try changing the setting on your PVR and see if that fixes the problem.
Menu, Settings, Television, Screen Aspect
I have only seen the white flickering line during the news 5pmPST, CTVVancouver. I will check again during the week. All other channels/programming seems fine.
1 - 6 of 6 Posts
