21 - 21 of 21 Posts
I looked at the same problem you did. I record stuff with my tuner on my desktop (SD analog cable) and I want to watch it on my TV via wireless.
I looked at all three consoles, and none were up to the task. Actually, the best console is an original Xbox, hacked to run XBMC.
Your best options are a media extender like the Popcorn hour, or something like a sage extender. I didn't want to spend any more money on OS licenses, proprietary software, change my trusty Win XP r anything of the sort. So build a basic HTPC, with Linux running on it. Mind you I already had leftover parts (memory, keyboard, mouse, hard drive, wireless adapter) so it cot me less than 300$ in parts.
Btw, make sure you set your computer resolution properly when connecting to your TV. If your TV is 1080i compatible only, chances are that your native resolution is something like 1366x768.
21 - 21 of 21 Posts
