Here's my issue: I own a D-Link 615 wireless router and a Tenda DSL modem (not wireless). My modem tends to get very hot if left on continuously so I turn it off before going to bed. I don't want my modem breaking down due to excessive heat (especially when I'm not home until late).
Problem is, when I come home from work and feel like going online or watching Netflix via my Xbox 360 or Wii, I turn on my modem and then have to keep rebooting my router because I keep getting a flashing orange light which doesn't go away unless I unplug my router.
Once I do that, everything is fine and works like a charm. I really don't want to keep doing this as it's become rather cumbersome and annoying. My question to you guys is should I go out and look for a modem that has proper ventilation (holes or openings around unit) or should I invest in a modem/router combo?
I really hate having to reboot my router everytime I get home.
Also, is 150 mpbs good enough or do I really need 300 mbps hardware? I'm on a 6mb dsl plan with 400 gb of monthly data.
I see a bunch of TP Link models around my budget. Any suggestions on what I should do or which brand?
Thanks!
Thanks!
