My Build
I built the Channel 7 10-element Yagi yesterday using a design from the VK5JDJ tool.
There was no discernable difference in performance between the Yagi and my GH10n3 (as per Nikiml) for the target channel 7 station (WBBZ). And I lost CHCH, RF11. Hence, I did not proceed to install the Yagi and instead dismantled it. The Yagi was a remarkably inexpensive and easy build. I used a 12 foot 2x4 as a boom (cost $4.14), eight of the 10 elements were build from scrap from previous builds and then sat it on top of two concrete blocks on a flat roof. Hence, when the performance did not live up to expectations, I put it down to learning. I did however take the opportunity to tune up my one-year old GH10n3 and it is now performing as well as it ever has.Another program you may like to use for a folded dipole Yagi calculation is Yagi Calculator from VK5DJ http://www.vk5dj.com/yagi.html
(I note that he just updated it in February with more features)
With it I get a folded dipole inside bend measurement of 820mm for 6.5mm material for 178 mhz.
