As many have said, cable is not tied to static IP policy. I've used Comcast (cable) in the US in the past with speed so fast that download status window from IE didn't even get enough time to calculate download speed before the download session would be finished. I used router with Comcast and it was easy to change MAC address and renew DHCP lease instantly (not a week) for exactly your purpose, darkman. There was also no throttling on popular file hosting sites. I could do GBs of downloads from say Rapidshare free account (no hotfile back then) no slower than with Rapidshare premium account.
My point is that, darkman, what your gripe about cable is not because of cable nature. It could just happen to be related to what your particular cable company does, but more likely I think is related to your limited technical abilities (as you suggested yourself).
BTW, like others have said. Use a router for security sake. It's much easier to setup than you think. Hack, there are even programs like jDownloader that contain a database of router scripts that can change MAC address (no it has nothing to do with a MAC/Apple) on your router in order to get a new IP for exactly your purpose. You just feed jDownloader all your hotfile links and the program will renew DHCP lease for a new IP (may need to reboot modem) after each download.
Now back to the original question. Like many have said, both cable and DSL technologies have matured so much now that any issue is more likely provider-related instead of technology-related. That means there is no quick answer to which of cable/DSL is better. It all depends on the particular providers in your neighborhood so it's better to gather info within your neighborhood, whether through this forum or not.
