Since re-arranging the components in my home theatre system, a ground loop has been introduced. I performed several tests to discover the source of the ground loop and have confirmed that it is caused by a new composite cable connection that I made between my plasma TV and the receiver. The power to the TV is on a completely different circuit than that supplying the other AV components. The composite cable connection to the TV completes the ground loop circuit. By chance I discovered that unplugging the HTPC power cord also eliminates the hum from the speakers.
In summary, the loop is: plasma TV power ground -> composite video cable -> receiver video output-> HTPC inputs -> HTPC power ground.
Can anyone suggest a ground loop isolator that is able to be used on the RCA video output from the receiver? It has to have sufficient bandwidth so as not to introduce distortion into the video signal. I know of the isolation transformer from The Source but it is a very poor performer and not suitable.
If such an adapter does not exist, is there another way to eliminate this ground loop?
TIA
- Robert
TIA
- Robert
