1 - 6 of 6 Posts
I just need one, and it needs to be the old style, anyone seen one for sale any where?
thanks!
Don
R1's are rare these days. Klipsch has killed Athena.
I'm thinking you're trying to upgrade from 6.1 to 7.1?
You could consider using them only on the sides and go for small regular bookshelves at the back. Either way, I think you're most likely looking at buying a pair not just a single speaker. The back speakers don't necessarily have to match the fronts.
just wunderin
Hello Jake.
Just curious if you still have the AS-R1.2 sitting in boxes in your basement ?
and if so, if you might be interested in selling them. As you well know, they're hard to come-by. Should have picked-up 4 on my outing to Rochester (bought them off of EBay, but Dear Wifey said that two should be enough:(
Best Regards,
Porthopeguy
Discussion Starter · #6 ·
ARGH, I just found one on ebay that ended last night, why do these things always happen to me? ha ha.
1 - 6 of 6 Posts
