In that case, a line amp may be the best option. You basically have two options, going to a very large non-standard dish (or two) or using a line amp. Line amps work better for amplifying a good signal, before too much line loss occurs. Placing them at the dish is best, but probably impractical in this case. Placing a line amp on the head end of the line going to the distant house should be sufficient.
ScaryBob,
We did try a Phillips SDW5005GN In Line Satellite amplifier => in place of, and again supplimental to, the Multiswitch => before the 250 feet of cable to the neighbors. We also tried it at the dish with a "butt" connector at the Cabin, and again just prior to Cable entry at the neighbor's house.
On a different Forum, someone suggested installing at the Dish with a Channel Master 5213IFD amp, saying it was a better quality device than most (?). But on Page 36 of the Channel Master Accessories book it says in reference to the 5213IFD:
"Care should be taken not to overload the amplifier (see specifications). Depending upon LNB gain, this will usually involve leaving a minimum distance of 100 feet of RG6U between the LNB and the line amplifier." (I'm not about to cut into the 350 feet of continuous RG6 Quad Shield that's buried in conduit in any case.)
Hence my confusion as I've seen various insertion points for these devices. There doesn't appear to be a "Bible" on installing these systems in non-standard situations. Nor is there much (any?) guidance from the hardware manufacturers, or even "retired" installers here in Canada. If the 75e doesn't improve the signal enough, I guess the last opton would be to migrate to RG11 cable, or investigate commercial grade amplification.
Of course the neighbor could wait for Telus to connect the Fiber cable that's about a Km. (or so) away on a telephone /BC Hydro pole => and forget the attempt at SD. We've heard from local electrical contractors that Telus has the stringing of new cables to the houses /cabins out for bid.
