1 - 11 of 11 Posts
· Banned
Discussion Starter · #2 ·
What features (iPod connectivity, USB, satellite radio, multiple zones, etc.) are you looking for? How many HDMI or other inputs/outputs do you want/need? Or are you looking for just a basic stereo receiver that will accept those devices?
I am basicly looking for the best receiver for Phono, Tape, CD, DVD, TV, VCR and Cable Box for under $300.
An iPod capability and a USB capability would be nice too, I don't need HDMI very much at all. Can anyone help me?
the best receiver for Phono...for under $300.
If you're hoping for a new home theatre/multi-channel receiver with phono for that price, good luck. Try the used market.
As for stereo amp, the Yamaha RX397 might fit the bill & budget, though it's a tad short on inputs.
· Super Moderator
I guess if you're happy with two channel sound and analogue audio inputs for your various devices, then you've got something that does that. The specs I read stated 4 audio inputs and you list 7 items in your first post, so I assume you're going to go "through" your TV to act as a switch for some devices, or use an external switch, or not connect something.
1 - 11 of 11 Posts
