Hi all,
I would need suggestion from you. Here is my problem, I have an Yamaha receiver that i bought like 8 years ago with the 5 speakers and the sub. It was an entry level kit and it fit perfectly my needs, but lately one of my rear speaker start to do "scratchy noise" (not sure if it's the proper term), i mean the speaker is bad. I can't find another speaker like this one, Yamaha doesn't make them anymore and anyway they do not sell the separately.
I need some small speaker due to my setup config, 4 inch wide max.
I was thinking about buying 2 new speakers and put them in the front, and use my 2 front yamaha that are still good as my rear. I was looking at the Polk audio RM7 but can't find them anymore, crutchfield were selling them for $59 each but only 1 left
I was also concern about replacing only the 2 front speakers without replacing the central?
Any suggestion, i didn't want to pay lot of cash to replace my speakers, the RM7 was a good option for me at $120 for both...
Let me know what you think guys.
The other option that i was thinking, Bestbuy are selling the Precision Acoustics HD25 5.1 kit for 299 instead of 780, but was wondering if it would worth it because of my receiver isn't that recent and it was an entry level and not an high end....
my receiver is yamaha htr-5830
Here is a link of my actual kit : http://www.yamaha.ca/av/Hometheatre/YHT160S.jsp
thanks for your help.
MaTT
MaTT
