Hi guys I have 2 tower paradigm phantom v4 , my center is a paradigm monitor series ccv3 cinema and i have 2 little satellites (infinitys) for rears
i currently have a 4~year old yamaha htr 5940 but it doesnt seem to have the power to push these fronts.
these are the towers specs
3-driver, 2-way bass reflex, quasi-3rd-order resistive port
High-Frequency Driver : 25mm (1in) CMC™ ceramic/metal composite dome
Two 165mm (6-1/2in) MPC™ metallescent cones, GRIP™ chasis
Low Frequency Extension (DIN) : 38Hz (DIN)
Frequency Response : 49Hz - 20kHz, +/- 2dB (on-axis) 49Hz - 18kHz, +/- 2dB (off-axis)
91dB / 88dB
15 - 160 watts
100 watts
8 ohms
Internal Volume 1.31cuf
37 x 7-3/4 x 12-5/8in
66 lbs per pair
the center is probably similar seeing that it was in the same range in the line up
i want something nice and loud , mostly movies 80% and 20% music listening
hd codecs and under 1000$?
91dB / 88dB
15 - 160 watts
100 watts
8 ohms
66 lbs per pair
