21 - 28 of 28 Posts
Discussion Starter #21
Great, thanks for the quick reply.
1. I guess I'll dig out my USB adapter if I can find it.
2. I was getting contradictory information from the phone agent while spending 15min activating (earlier spent 15min getting it activated with Live Chat, didn't work and the phone agent said the PVR wasn't listed in my account and the 940 was still active). First she said some channels are auto tuned so CTV2 on 6 is HD. Then she told me it wasn't HD. But the HD light is on when I'm watching 6. Does that mean it's HD, and if so where am I likely to find the SD feed?
Thanks again!
Discussion Starter #23
Just checked and the guide shows CTVOT on 109 and while it's still letterboxed, the HDTV light went out.
Does it make sense that Rogers has put the HD feed on the traditional channel, and the SD feed on some other arbitrary channel, buried in the middle of the out of town channels (ctvml, ctvot, ctvwn, ctvca, ctvbc)?
Also, is there any valid reason why they don't do what Bell does, where ctvsd=201, ctvhd=1201 (or tcm=338|1338)? Two older relatives each got tcm recently, one has to learn a whole new number which I can't remember either, and the other has to remember to put 1 in front. :( for Rogers.
Thanks!
Discussion Starter #24
Thanks, I guess we posted at same time. Good to know I should find more up there. Maybe I'll dig out the ancient TiVo I have with 500GB and see if it's compatible with this PVR and reformat. Was planning to save that for when I get a HD TV, no point in doing it now and then get a NB3 it something at the same time. Might be worth the effort to save aggravation learning all new channels for SD.
The timeshift channels in the 100s are SD. For example, CBC 127 and various ones around there.
Rogers has a lot of older legacy customers who were used to the old numbers, so they kept them. Rogers groups many channels by theme - news, sports, kids, music, movies, etc
In order to use the TiVo, you'll need to have it downstream of the Rogers STB and have the Rogers STB tune the channels because almost nothing is available on analogue.
http://www.digitalhome.ca/forum/30-57s-home-theatre-faqs/76077-faq-how-connect-vcr-dvd-recorder-stb.html
http://www.digitalhome.ca/forum/37-rogers-cable-tv/146605-rogers-analogue-digital-migration-read-post-1-a.html
No need to learn new channels, just put a few of them in the list of favourites in the guide. Also, once you've set up some series recordings, the single recordings shouldn't take much time.
Discussion Starter #27
Thanks, those are good points. And I didn't express myself well before, I actually did (do) have an old TiVo hooked up to (and driving) the 940 STB. I'm thinking of putting it on the PVR (via composite or svideo) and running the PVR directly to TV via coax. Then anything recorded on both I can delete from PVR to save space and enjoy the TiVo interface (80GB of SD > 160 GB HD). This TiVo has lifetime service, required to use it this way.
However I also have a SD TiVo that I upgraded to 500 GB in 2010 and I'm thinking if the _drive is compatible I could move it over (reformat etc.). It's almost certainly PATA, and it's a PVR/DVR rated drive (bought on eBay specifically for TiVo). Probably a topic for the other upgrade thread.
Thanks!
Discussion Starter #28
Thanks again for the advice and support. I've been running the 160GB from an old 8300HD (cable company now defunct) with no trouble (a little pixelation but it's still very infrequent). I've since found my SD Tivo with the upgraded 500GB and pulled the drive (needs both T10 and T15 drivers, but not security).
I added a post to the sticky thread (which itself has been incredibly valuable, I think I've read it all!). But to close things off here, this drive is a 500GB Seagate DB35.3 model ST3500830ACE. I bought it on eBay about 3-4 years ago and upgraded my 80GB SD TiVo. It was sold specifically to be used with a TiVo and in fact came preformatted and with whatever special stuff TiVo uses already loaded. It worked well for about 2 years (2010-2012) both on Comcast (FL) and up here, until the cable company folded and we got dumped onto Bell Fibe. Meanwhile Comcast went the Rogers route and cut back analogue to 2-26 or whatever (probably now requires a DTA), so we invested in a CableCard and HD TiVo for Comcast.
I don't recall any noise issues with the drive. Can I just drop this into my 8300HD and then force a reformat? This is different from the 160GB, which did require a reformat to clear the old recordings but appeared to be able to record new shows as-is. My HD TiVo only has 320GB but I can pull recordings off it onto an external connected to my notebook, so its capacity is essentially unlimited (just a lot of work when there's a lot recording).
Thanks!
=aw
21 - 28 of 28 Posts
