1 - 7 of 7 Posts
Okay I have a pretty simple question. I know Telus HSPA runs on 850/1900 BUT is there any apps or way of telling what frequency I am running on at a specific location? I ask as I need to add a repeater inside my office build as the cell reception is terrible! but I dont really want to buy both frequencies if I can figure out what is being used in this location. Is 1900 the standard for Calgary?
I have tried a few android apps but non thus far have shown the frequency best I could get was data is on UMTS and ca HSDPA.
So should I just get a 1900 and hope its right or figure out how to tell what im running on here
Discussion Starter · #5 ·
That being said I did find a dual band repeater That is only about $350 with shipping so I might just go that route and hope its stong enough for the office. as compared to a bit more robust system
Just read some reviews on the Zboost I was thinking of, well does not sound so good so sounds like back to single band for now.
1 - 7 of 7 Posts
