1 - 2 of 2 Posts
I'd like to start a discussion on what would be considered good GH parameters from a building perspective.
I'd like to know your opinion on the following.
1. Maximum feed gap
2. Maximum gap between colinear reflectors.
3. Maximum length of a half reflector (half of the max antenna width)
4. Maximum antenna height
The general question is at which point one would consider those parameters to be a more important decision factor than the gain/swr curves?
Please have the numeric portion of your replys laid out in the form:
max_feed = value
max_gap = value
max_hlen = value
max_height = value
so I could copy to a spreadsheet
So, youre looking for design constraint measurements from a practical available size standpoint ?
1. Maximum feed gap That should be as far as a typical balun can stretch for mounting. Baluns vary in that regard. And you could use extenders. I would say about 5 inches.
That would be limited by the plastic tube you could get. The grey pvc rain gutter ferrule is 5" (perfect for 3/8" tubing), and you would want to leave about 3/4" of the ends in there, so that would leave about 3.5" for the gap. Of course there are other mounting methods and other tubes.
The max width of commonly available mesh sold, is 48". The longest element on Vhf antennas with 3/8" tubing was 54", and that element typically took a beating. I would say 39" (1 meter) in length max for stand alone 3/8" tubing so it would hold up over time.
You would want to work on an antenna without using a step ladder. A six foot tall person can comfortably reach and use pliers up to about 90". If the antenna is mounted in a 12 inch stand, that would leave about 78 inches as the maximum height.
1 - 2 of 2 Posts
