1 - 5 of 5 Posts
Has anyone else noticed that the Weather network local feed is now from Abbotsford instead of Vancouver on Shaw? Update, I have discovered that it is only digital that is mixed up. When I use the analog signal it comes from Vancouver.
They told me to unplug my box (Shaw), then they told me to get a reset, then when that didn't work, they said they were getting complaints from others ie a known issue. But let them know that you want it changed back otherwise they may just leave it as is.
1 - 5 of 5 Posts
