Background:
At the beginning of this year, I switched from Bell POTS to voip.ms. I kept my Bell Internet (dry loop now), so I still have the Bell 2wire modem-router. My VOIP adapter is a Linksys RT31P2. It is a router but I use it as an adapter.
I set up the adapter as suggested by voip.ms and Mango’s Linksys page. There have been a number of issues over the last three months and I will mention them briefly, as they might affect the issue I am writing about now.
In January, my adapter was losing registration every few minutes. Voip.ms suggested I switch from toronto2 to montreal2 (which I am still on), and use the IP address for Montreal2 (174.142.75.171) in my adapter settings. They also added a NAT keep alive setting for my account: “this will help for taking the connection as active always… The NAT Keep Alive is an option from the server's end to keep sending keep alive packets to your device in addition to what your device is sending. This is basically to help keep two way communication intact and not lose registration…”
Earlier in March, people could not hear us when we dialed out. On March 15, voip.ms made a routing change on my account. However, this seemed to create another problem: calls coming in would stop ringing after 2-3 rings, although those calling us would continue to hear a ringing sound. Voip.ms suggested this was a hardware problem, or that I should re-set the adapter to its defaults settings. However, I later figured out that the problem was being caused by a setting on the voip.ms Manage DID page: Dial Time Out in seconds. I increased the number of seconds and the problem stopped. The odd part is that the Dial Time Out setting was fine from January to mid-March, i.e. pretty much until voip.ms made a routing change on my account.
Current Problem
So now I am left with one problem, which is not as serious as some of the others I’ve had, but I’d still like to remedy it. When I pick up my phone to make a call, I get a dial tone immediately, but there is about a 10 second wait between when I finish dialing and when I hear the line ringing. Coincidentally or otherwise, when I call home from elsewhere, I also have to wait 10-12 seconds before I hear the line ring. Someone calling me might think that the phone was not working, since 10-12 seconds is longer than you normally wait for the ringing to start.
Voip.ms suggested I change an adapter setting: the Interdigit Long Timer. It was at 10 and they suggested I change it to 0. However, this did not seem to make a difference.
My dial plan, might be a factor, so here it is:
(<:1416>[2-9]xxxxxx|1[2-9]xx[2-9]xxxxxxS0|[2-9]xx[2-9]xxxxxxS0|*xx|*xx.|[3468]11|911S0|822|0|00|[2-9]xxxxxx|4XXX|xxxxxxxxxxxx.)
Voip.ms suggested I remove the period right before the last bracket, but that did not seem to make a difference either.
I am beginning to think that there is something about the routing change that voip.ms made on March 15 that is causing these recent problems. However, they don’t see it that way, and I agree that a routing change for an outgoing call shouldn’t affect the time it takes for an incoming call to connect (although perhaps it is the cause of the outgoing delay). And I don’t recall this being a problem In Jan- Feb; there was a delay, but 3-4 seconds rather than 10.
I would appreciate any suggestions. Thanks in advance.
Current Problem
