1 - 20 of 77 Posts
Hi,
I have a 8300HD and a external hard disk Esata Appricorn. It worked fine for many months, until Videotron upgraded the OS of the machine. Since then, the new recording shows in the menu, but they dont play, unless they have been recorded in the inner hard disk. I called Videotron, we downgraded the OS, upgraded it, reboot many times, it did not work, I still experiment the same problem.
Any idea? I am thinking off taking the Apricorn disk and put it inside 8300Hd box. How do I do that?
David
1. Sounds like a connection issue with the eHDD, or something wrong with the drive or enclosure since it'll play internal fine. Topic discussed extensively in the following thread. Read post 1 for starters.
http://www.digitalhome.ca/forum/showthread.php?t=23773
2. You cannot use the SATA drive internally without an adaptor - discussed in the following thread.
http://www.digitalhome.ca/forum/showthread.php?t=94262
Suggest you use the appropriate Rogers threads for any further questions on i/eHDD even though you're with Videotron.
Check out the following post, useful for those new to the forum - FAQs, Search tips, optimization, etc.
There's also a Videotron firmware thread where problems were discussed:
http://www.digitalhome.ca/forum/showthread.php?t=121986
eHDD Sleep mode problem
Hello,
I just added an external hard drive a few days ago to my SA8300HD (I used a WD1001FALS Caviar Black Hard Drive, with a NexStar 3 NST-360SU-BL enclosure). When I set it up, the pvr detected the hd, and everything looked to be working perfectly, but now I am running into a problem every night when the pvr goes to sleep.
Every morning, when I go to check the space used on my pvr, it shows the percentage used on my internal hd, and I cannot play any of the recordings from my external hd. If I reboot the pvr, it detects the external hd and all my recordings work again. I'm guessing my HD goes into sleep mode during the night and the pvr never wakes it up or something. Has anyone else run into this problem, and knows how it can be fixed?
Thanks!
Suggest you check out the following thread in the Rogers forum on the eHDD. I don't recall this issue with the Black drives (some of the green ones had issues).
Videotron has different firmware from Rogers which might have an effect. Here's that firmware thread where some eHDD problems were discussed - check out the last few pages where people discuss eHDD issues (do two cold reboots and make sure you wait for the eHDD to "wake up" when you turn on the PVR were both mentioned there.)
Add external HD to 8300HD+
I have an 8300HD+, and the internal disk is pretty much constantly full.
I want to add an external disk. Is it just a matter of buying pretty much any eSATA enclosure and a SATA disk, and plugging it in?
I searched the FAQ and such, but either the info seems to apply to the 8300HD (not sure how different the 8300HD+ is), and also some of those posts are quite old, and there is mention of a converter board, and not quite clear how that applies and such...
I would buy a 3.5" enclosure where you can return it if it does not work. The adapter is only for internal upgrades. Best to stay clear of that or just get the 500GB WD drive everyone is using internally. For external just about any enclosure will work if it does not have these features.
Power saving, backup, gauges
extra ports (firewire for example)
Seagate drives
I say all this but I have and many of us here have the 8300HD. I presume the PLUS only signifies an upgraded internal drive.
I have a 1GB internal but I am very lucky (in that it works) and would not recommend it to just anyone.
For EXTERNAL hard disks,
I know to get a WD "black" series hard drive.
is there a particular enclosure that is "recommended" or known to work?
Also, I recall reading in the FAQ that I need a SATA1-to-SATA2 cable....but there is also an eSATA cable...is that different?
The SATA1 cable reference you saw is out of date. Now all enclosures use ESATA. All enclosures I have seen come with the correct cable (ESATA-ESATA) so there is no need to buy one. The WD Black series is a solid drive. A lot of people used the Vantec Nexstar ESATA/USB enclosures (NST-360SU).
Same issue External Drive
I have the same issue with my Western Digital drive, I can't read what was recorded on it and can record new shows but I'm not able to watch them. I had to unpluged it to find that the issue was with my external drive. This happen just after the last firmware upgrade for my 8300 recorder.
explorer 8300 hard drive add on when not PVR?
If I get the explorer 8300 regular terminal from videotron, or maybe the HD model, could I get a SATA compatible external hard drive to turn it into a PVR? Ive got a 1T external and wanted to know if I could save money on a PVR by just getting a regular terminal. Thanks
Simple answer. No. You'll need to get the 8300HD if you want the PVR, although you can add an external drive to that for additional storage. (lots of threads around here discussing if you need more info)
SA Explorer 8300HD with external HDD
Hi all,
I presently have a Videotron SA Explorer 8300HD with the 320Gb internal disk. I wanted to add an external hard disk using the e-sata port on the back. I was told that the Fantom GF2000EU G-Force External Hard Drive - eSATA, USB 2.0, 2TB, 32MB Cache was a fantastic, stable HDD unit.
Can someone tell me if it's compatible with my explorer 8300HD? I will be buying on the internet and I don't feel like returning it if it's not compatible.
Please I need help with this question!!!! Does anyone know if there's a maximum capacity external HD (ex. MAX 500Gb) or will the 2Tb external hard disk work on my machine?
Thanks for your help!!!
Jean-François Levesque:confused:
see all the responses in this thread and the links posted. It should answer all your questions. Please search before posting.
As per post 2 of this thread, check out the following thread in the Rogers forum, which uses the same equipment. Read post 1 of the thread carefully and thoroughly.
I don't believe anyone has a 2TB eHDD operational yet (that we know). As per post 1, the largest has been 1.5GB, however, 1GB should provide more than enough room for time-shifting needs. The 1GB WD Black Series is "recommended".
1 - 20 of 77 Posts
