Note to moderators; this should probably go in a FAQ somewhere
How to find out what video modes your HDTV will support. I developed this idea after reading http://www.mythtv.org/wiki/Modeline_Database
The output very nicely contains the names to use in the "Modes" decalaration of
Subsection "Display"
In my xorg.conf, I can stick in...
to cover playback of standard streams I capture from OTA TV. If you collect Youtube clips or download other videos, you can choose additional modes as required. Or you can set up scripts to launch X using different versions of your xorg.conf file.
- Connect a computer to an input of the HDTV, and boot linux on it.
- If you're currently running X, shut it down and go to a text console
- Restart X with the command
Code:startx -- -logverbose 6
- Exit X and move or copy file Xorg.0.log to another name so that it doesn't get clobbered next time you run X (may require root/sudo permissions). You may now restart X if you wish.
- View the saved copy of the log file with your favourite editor or file viewer. Look for the 2nd or 3rd occurence of the string "ModePool".
Code:
(II) Dec 27 23:35:13 NVIDIA(0): --- Modes in ModePool for PANASONIC-TV (DFP-0) ---
(II) Dec 27 23:35:13 NVIDIA(0): "nvidia-auto-select" : 1280 x 720 @ 60.0 Hz (from: EDID)
(II) Dec 27 23:35:13 NVIDIA(0): "1920x1080" : 1920 x 1080 @ 59.94/60 Hz (CEA-861B Format 16) (from: EDID)
(II) Dec 27 23:35:13 NVIDIA(0): "1920x1080_60" : 1920 x 1080 @ 59.94/60 Hz (CEA-861B Format 16) (from: EDID)
(II) Dec 27 23:35:13 NVIDIA(0): "1920x1080_60i" : 1920 x 1080 @ 60.1 Hz Interlace (from: EDID)
(II) Dec 27 23:35:13 NVIDIA(0): "1920x1080_60i_0" : 1920 x 1080 @ 59.94/60 Hz (CEA-861B Format 5) (from: EDID)
(II) Dec 27 23:35:13 NVIDIA(0): "1440x480" : 1440 x 480 @ 60.1 Hz Interlace (from: EDID)
(II) Dec 27 23:35:13 NVIDIA(0): "1440x480_60i" : 1440 x 480 @ 60.1 Hz Interlace (from: EDID)
(II) Dec 27 23:35:13 NVIDIA(0): "1280x720" : 1280 x 720 @ 60.0 Hz (from: EDID)
(II) Dec 27 23:35:13 NVIDIA(0): "1280x720_60" : 1280 x 720 @ 60.0 Hz (from: EDID)
(II) Dec 27 23:35:13 NVIDIA(0): "1280x720_60_0" : 1280 x 720 @ 59.94/60 Hz (CEA-861B Format 4) (from: EDID)
(II) Dec 27 23:35:13 NVIDIA(0): "800x600" : 800 x 600 @ 60.3 Hz (from: X Server, VESA)
(II) Dec 27 23:35:13 NVIDIA(0): "800x600_60" : 800 x 600 @ 60.3 Hz (from: X Server, VESA)
(II) Dec 27 23:35:13 NVIDIA(0): "720x480" : 720 x 480 @ 59.9 Hz (from: EDID)
(II) Dec 27 23:35:13 NVIDIA(0): "720x480_60" : 720 x 480 @ 59.9 Hz (from: EDID)
(II) Dec 27 23:35:13 NVIDIA(0): "720x480_60i" : (1440)x 480 @ 59.94/60 Hz Interlace (CEA-861B Format 7) (from: EDID)
(II) Dec 27 23:35:13 NVIDIA(0): "700x525" : 700 x 525 @ 60.0 Hz DoubleScan (from: X Server)
(II) Dec 27 23:35:13 NVIDIA(0): "700x525d60" : 700 x 525 @ 60.0 Hz DoubleScan (from: X Server)
(II) Dec 27 23:35:13 NVIDIA(0): "640x512" : 640 x 512 @ 60.0 Hz DoubleScan (from: X Server)
(II) Dec 27 23:35:13 NVIDIA(0): "640x512d60" : 640 x 512 @ 60.0 Hz DoubleScan (from: X Server)
(II) Dec 27 23:35:13 NVIDIA(0): "640x480" : 640 x 480 @ 59.9 Hz (from: X Configuration file ModeLine)
(II) Dec 27 23:35:13 NVIDIA(0): "640x480_60" : 640 x 480 @ 59.9 Hz (from: X Configuration file ModeLine)
(II) Dec 27 23:35:13 NVIDIA(0): "640x480_60_0" : 640 x 480 @ 59.9 Hz (from: VESA)
(II) Dec 27 23:35:13 NVIDIA(0): "640x480_60_1" : 640 x 480 @ 59.94/60 Hz Interlace (CEA-861B Format 1) (from: EDID)
(II) Dec 27 23:35:13 NVIDIA(0): "512x384" : 512 x 384 @ 60.0 Hz DoubleScan (from: X Server)
(II) Dec 27 23:35:13 NVIDIA(0): "512x384d60" : 512 x 384 @ 60.0 Hz DoubleScan (from: X Server)
(II) Dec 27 23:35:13 NVIDIA(0): "400x300" : 400 x 300 @ 60.3 Hz DoubleScan (from: X Server)
(II) Dec 27 23:35:13 NVIDIA(0): "400x300d60" : 400 x 300 @ 60.3 Hz DoubleScan (from: X Server)
(II) Dec 27 23:35:13 NVIDIA(0): "320x240" : 320 x 240 @ 60.1 Hz DoubleScan (from: X Server)
(II) Dec 27 23:35:13 NVIDIA(0): "320x240d60" : 320 x 240 @ 60.1 Hz DoubleScan (from: X Server)
(II) Dec 27 23:35:13 NVIDIA(0): --- End of ModePool for PANASONIC-TV (DFP-0): ---
Code:
Modes "1920x1080" "1280x720" "720x480"
