1 - 13 of 13 Posts
I always see cheap USB sticks in the front bins at my local Staples. Not sure if they have 16GB ones on clearance yet
canadacomputers
ncix
memoryexpress
and i often see good deals on dell (free purolator shipping is a plus)
Avoid staples unless it's a super, super deal. Like the $10 16gb one last weekend. Chances are their "sale" price will still be more than regular price at computer shops, like those listed above.
FS & BB are the same, tend to be overpriced except on super sales.
Just got an email from OFFICE DEPOT today. They have a 16 gig drive for $23. Regular price is $40. That is $17 off. The offer is also good on line as well as in store. The offer is good from today (Nov 29) to Dec. 3.
sailmaker
Just a side thought here for you as I encounter this issue the other day. If you plan on using the drive for LARGE over 4gb then you need to format your usb drive to NTFS, not fat32 :)
If you are in windows you need to change a setting under computer management-system tools-device manager-disk drives-then choose your drive, go to properties, then policies and change to Optimize for performance. Now you can re-format in ntfs under windows explore.
I found this out after copying the drive almost full then had to move everything off it to reformat it so I could get the other files I wanted on there.
Be careful with the o'ptimize for performance' options if you aren't a 'safely remove' follower.
That's a write cache setting, so if you dont give it time to complete writes before you pull, you might have data corruption.
Discussion Starter · #12 ·
Thanks, but I am not interested whatsoever in mail in rebates. Just looking a good deal outright. But thanks for the tip :) Still looking around for a steal.
1 - 13 of 13 Posts
