1 - 3 of 3 Posts
Hi there,
I recentely purchased a used 5200 receiver. Prior to this I had the regular SD single tuner receiver. The dish on my place came with the house and is about 10 years old. (One LNB p/n 214-5100-402)
I need two inputs and only have one at the moment. I took off the LNB and see there is actually two cable hook up available. Do I just add another cable and run it into my new dual tuner receiver?
Just want to make sure this won't cause a major issue before I try. Lot's of conflicting information out there and not sure if it all applies to my standard definition situation.
Any help is much appreciated.
Cheers,
Russ
No problems at all by just running the second feed from the LNBF, that is exactly how it needs to be done.
1 - 3 of 3 Posts
