1 - 2 of 2 Posts
We want to upgrade our system in Canada to a HD/PVR which means getting a new dish/lnb, we just have the old cylindrical lnb right now. BUT... in mexico we have the same, both running old dsr-305's. If we change everything in Canada will the old one still work in mexico or will we have to change the dish and lnb there as well?
someone said it has something to do with stacked/unstacked lnb's and something they do at Shaw so that the HD/PVR will work.
Thanks for any info.
upgrade in Canada and tell them not to change the dish codes on the receiver's that are in Mexico. As long as they are not changed, no problem. Give them the serial numbers for the ones in Canada and tell them to leave the others alone.
1 - 2 of 2 Posts
