101 - 117 of 117 Posts
I have a 9865 Nextbox 3.0. I experienced problems with the unit's original Seagate 1TB HDD about 2 years ago, and replaced it with a new same model Seagate HDD. The new HDD fixed all the recording/operational issues. Everything has worked fine with the unit until very recently. For the last couple of weeks I've been getting frequent/intermittent video freezing and/or no sound and/or momentary pixelation when I play back new recorded shows or movies. Recordings I've had from long ago play back just fine, no problems at all. I've checked and the signal into the 9865 is great, as is the S/N ratio. I don't know what the issue is, but I suspect it's being caused by Rogers somehow or other.
Does anyone have any thoughts on what the issue could be? I can't believe I need to replace the HDD again in my 9865 unit!
Thanks, Richard
Are you hearing any clicking noises when the problem occurs? That's often an indication of a failing drive.
If you replay the "problem" programme, does the same thing happen at exactly the same time? If so, it could be a problem with the "write" phase, or it could be an issue with the incoming programme signal?
What about when you do "pause live TV"? If you watch programing live and there are no issues, but if you REW and watch the same programme but see issues, then that points to a problem with the iHDD. Do some more experimentation with a regard to what goes wrong and you should be able to pinpoint to the problem.
^ Hello 57 - thanks for your response.
No, I'm not hearing any clicking noises when the problem occurs.
If I replay the "problem" programme, the same thing happens at exactly the same time.
If it's a problem with the "write" phase, would that mean the HDD must be at fault?
I think the issue might be caused by a problem with the incoming programme signal - I've discovered that certain Rogers HD channels cause the issue to happen more often than others. I've also noticed lately - when I'm looking for it - that live TV sometimes freezes for a split second, or the TV screen pixelates very briefly, which would no doubt cause the write process (when the unit is recording) to have fits. I wonder if Rogers is messing around with unusual programme signal compression nowadays?
I picked up a tip from the Rogers Community Forums - I'm currently experimenting with a different "TV Type" under the category of 'Appearance' in the Settings menu for my 9865. If the issue is the incoming programme signal my 9865 may have an easier/better time with the TV Type set to 720p or 1080i versus the 1080p option.
1080i is probably the best setting. The TV will usually scale to 1080p better than the 9865 will.
I notice dropouts on some channels occasionally. It seems to happen frequently some days and not others. It could be due to atmospheric or network conditions. The worst are the Seattle network stations.
....certain Rogers HD channels cause the issue to happen more often than others.
If the issue is with SDV channels or specific channels in the higher QAM frequencies, then you may have a temporary or channel-specific signal problem even though other channels are fine. Check the signal on the problem channels at various times of the day. I recently had issues with the signal falling after about 11PM... Yes, try 1080i.
UPDATE: Changing the TV Type setting did nothing to alleviate the new recording playback problem as described in my earlier post. Signal strength and S/N Ratio have proven to be excellent on every channel I have checked. I decided yesterday to carry out a factory reset of my 9865 to see if that might resolve the issue, an action which (of course) resulted in losing all of my long-time saved recordings. :( Unfortunately the factory reset did not alleviate the new recording playback problem. My next plan of action (today) is to remove the iHDD from my 9865 and wipe the drive (i.e. fill all sectors with zeros). Later, when I reinstall the wiped iHDD and boot up my 9865, the unit should carry out an automatic formatting (HddF) of the drive, etc. If, after all that, the new recording playback problem still exists, I will pronounce the HDD defective (in terms of its "writing phase" abilities) and purchase a new iHDD. If I buy a new iHDD I'll be looking to get the latest Seagate SkyHawk 1TB Surveillance 3.5" HDD available on Amazon.ca for the current price of $76.49. Will provide further updates as I proceed.
/RB
The quickest way to test the drive is to perform an extended SMART test. I use a program called GSmartControl. It will show drive statistics and possible imminent failures due to low level errors.
10/09 UPDATE: Yesterday I removed the 1TB iHDD from my 9865 and wiped the drive (i.e. filled all sectors with zeros) using the downloaded free version of a Windows-based program called Macrorit Data Wiper. The program is extremely easy to use, and the entire wiping process took about 2 hours. After that I reinstalled the wiped iHDD into my 9865 and powered up the unit. The unit rebooted 3 times, and after one of the reboots the unit carried out an automatic formatting of the drive (my 9865 displayed "HddF" during the process). After all the processes were complete my 9865 was working fine/normally and I decided to record a couple of 1 hour TV shows. I watched both shows last night and I'm happy to report there were no problems whatsoever with the playback. I'm guessing the original playback issue (on new recordings only) was caused by some corruption that existed on the drive disc, however caused. We'll see over the coming days & weeks whether my 9865 continues to perform well with respect to recorded program playback.
^ ExDilbert, thanks for your reply. I did not perform an extended SMART test per your mention/suggestion, however I may investigate that particular exercise some time in future should the need arise.
While this is an old thread, I figured I would share my experience as I just replaced the HDD in my 9865 and there may be others still rocking these boxes.
A few weeks ago the box started freezing up and rebooting randomly and I found this site, and based on this thread, it sounded like my HDD was failing so I decided to replace it and try to retain my recordings and used posts #7 and #38 for guidance. My original HDD was a Seagate Video ST1000VM002 1TB (manufactured November 2013) and I replaced it with a Seagate Surveillance ST1000VX005 1TB. I decided to purchase a dual bay HDD docking station (WAVLINK USB 3.0 to SATA I/II/III Dual-Bay External Hard Drive Docking Station for 2.5/3.5 Inch HDD/SSD with UASP (6Gbps), Support Offline Clone Duplicator and Auto Sleep Function [12TB X2 ]-Black: Amazon.ca: Computers & Tablets) and do an offline clone of the drive which took around 2 hours. My original HDD was 50%+ full. When I powered the box back up, at some point I saw "Hddf" on the display which was not a good sign that my recordings were retained. When booting completed, I went to the list which seemed to show all of my recording and scheduled recordings. However, it displayed only 0.5% (or maybe 0.05%) full and the number of recordings seemed to be rapidly changing. I exited the list and when I later checked, all of the recordings were gone, but the scheduled recordings were still there. This seemed similar to post #61. I thought maybe there was an issue with the clone. Or maybe the drive did get formatted by the box as it saw it as a "new" drive, but that did not seem to make sense since the recording setting were retained.
I wasn't ready to give up on my recordings yet, so I decided I would try another offline clone and failing that, a clone using software through the computer and failing that, accept defeat that my recordings were lost. I am happy to say that the second offline clone worked. When I powered back up, it just went through the regular booting process (with no reboots) and everything looks to be the same with all of my recordings and recording settings.
I installed a Samsung 500GB SSD in my bride's PVR... after a long while, the time showed. Tried it, and it was back up and running great. Before changing the HD it was showing 85% full, with on a few short movies, and it took 30 seconds or more to respond to input. Once new SSD was installed and formatted, it was like a new computer - very quick responses.
Edit by 57: Unnecessary Quote Removed.
I replaced hd in my nextbox 3 pvr because it was stuck in boot. It now goes thru a downloading process and comes up with the cisco screen and gives an ed98 code?
Formatting the drive in a computer should do the trick. There are also disk wipe utilities. And in Linux you could use dd to write all zeros to the entire disk.
Just FYI, in Linux you don't need to zero the whole drive, you only need to nuke the very beginning where the "table of contents" (drive map) is stored:
sudo dd if=/dev/zero of=/dev/sdX bs=1M count=10
# where sdX is replaced by the device you are wiping...../dev/sdb, /dev/sdc, etc. BE CAREFUL NOT TO WIPE YOUR OS DRIVE!!!! (usually sda)
If you're on a Mac, use "bs=1m"
In theory you only need to wipe the first 512 bytes to clobber the MBR and map, but 10MB is done in the blink of an eye anyway, expect the above to complete in a fraction of a second.
Cheers!
Hi everybody,
It appears it is a hard drive issue, but before I spend money on a new one (and some tools), I thought it would be a good idea to consult people.
I have 2 Nexbox 3.0 units, connected in Whole Home PVR system. One of them is still working fine, but the other one failed miserably a few days ago. I have first noticed that it refuses to record anything. The tuner is fine and I can watch any channel, but the PVR functions are all dead. Not able to record, creating no buffer, so I cannot rewind live program, and also all my previous recordings are gone. The drive is empty. As for WHPVR functionality, it sees all recordings on the other PVR, but cannot play any of them.
I did the factory reset, and it did not help.
As I said, it sounds like a dead hard drive, but could it possibly be something else? Also, would any SATA drive work (I would probably just go with another 1 TB drive)? I have found a post here on this forum, which describes the process of installing a new drive, and it mentions Torx 10 and Torx 15 screwdrivers. Are those the only tools required?
Thanks in advance!
Hi everybody,
Thanks in advance!
I had similar problem and just replaced the SATA drive with a 1TB and it worked fine. You need the torx anti tamper bits but once the cover is off its clear how to replace the drive, pretty straight forward. I had previously removed the motherboard and did an alcohol wash but probably didn't need to.
Thanks for the reply. I ordered a WD Blue 1T from Amazon, plus a set of Torx tamper proof bits. Should get it in a few days, and I hope everything will go smooth.
