1 - 16 of 16 Posts
I want to upgrade from a 3100 to a 6131 receiver and wanted to know if I needed a new dish or whether I could simply add a LNB to my existing dish and fix the skew to get 82? Not sure what model or size the dish is, but it came in a kit with the 3100, and I bought it back in 2005. I believe there is a slot on the arm for a second LNB.
Also, should I go for a dual LNB?
What else would I need?
I want to avoid having to remove the dish completely and reinstall a new one. Many thanks.
If it has a slot for a second LNBF then you have the correct Dish.
Climb up and check the skew setting, if it was done by a Bell Installer, it should already be skewed for you.
If all you have now is the 3100, all you would need is an SW21, with a feed from each LNBF, then from that, you can use the existing cable that is feeding your 3100 or run a new line.
Thanks for the information. Couple of more questions before I attempt this: Will any lnb do the job? Is setting the skew fairly straightforward--I fear disrupting my existing arrangement. Thanks again, and great forum btw.
All you need for the skew is a 7/16" wrench.
Any Bell or Dish Legacy LNBF will be fine.
Try installing a second LNBF and SW21, then run a Check Switch with your 3100, this will tell you if you are getting 82. NOTE; Not ALL transponders on 82 are visible with a 3100.
Just as an FYI, if this is your first HD receiver to be added to your account, I believe Bell still do this for free, might be worth a call, save you some grief.
Discussion Starter · #6 ·
So got everything setup. Did a check switch and it shows that both odd and even transponders for 82 are ok. However there is 0 signal for sat 82. Is this because of the 3100, and therefore should I get the signal when the 6131 is connected?pretty sure I've got the skew right. Thanks.
Transponder 1, should show signal on 82 with a 3100, there are other but I can't remember right now.
Hi,
I currently have 2 3100 receivers and want to upgrade to 2 6131 receivers. I'm not sure what dish I have or where its pointed to. It was done by Bell a couple of years ago. I have 2 cables coming into my house.
I was told by Bell they would charge $75 to install the 1st receiver and $50 for the second.
Can I just hook up the 6131s?
Try calling Bell again.
You should be entitled to a free Upgrade if you are going to HD or programming from 82 for the first time.
To see what Satelittes you are aimed at, run a Check Switch, MENU, 6, 1, 1. When it finishes, it will say if you are getting 91 & 82 and the type of switch's if any.
91 was checked, 82 was unchecked. Is that good for HD or bad?
Last time I called bell, they said I would have to take a extra HD package for a year to get free installation. I only wanted the basic package with the few free HD channels.
Thanks for your help Pinza.
You need 82 for the HD Channels.
So I would say the easiest and cheapest way right now is to get a DPP Twin LNBF, see this thread;
http://www.digitalhome.ca/forum/showthread.php?t=79128
It will slot in at the end of the "Y" yolk on your Dish, just connect the 2 lines to the 2 x Outputs and you should be good to go with a pair of HD Receivers.
Ther is nothing to stop you putting the 6131's on the lines now as a straight swap for the 3100's, at least with an External hard Drive they would become PVR's until you change the LNBF, when you would then get the HD as well.
Just wanted to alert gackie that you can have up to 6 receivers on account. The equipment that will probably be added to allow the 6131's will probably include a SW44 or something similar which will allow 4 receivers to be hooked up, which would mean if you have a use for the 3100's you could keep them hooked up.
The last time I talked to Bell, they said a customer in good standing is allowed 2 upgrades per year, which I think should cover the install but it also depends on who you talk to.
I was hoping not to have to make modifications to the dish, since it's on the roof and I don't have a ladder :) I guess I'll need an installer. Thanks Pinza.
Thanks for the info dirtroad. I won't really need the 3100s and I'll kinda be glad to be rid of them.
I'll give Bell a call and try to get the install for free. Thanks for your help guys.
You should be able to sell those with no problem as they are the best std. def. receivers Bell has ever had in my opinion, I like more than the 4100. I have one that I rotate in and out of my active receivers to have as a spare.
Have you talked to Bell about trading up or is that what you are doing?
Dirtroad, I'm just buying new HD receivers, I didn't know you could trade up. They offered me a $75 credit if I by one from them. Does anyone know if I can buy a receiver from Bestbuy and still get the credit?
1 - 16 of 16 Posts
