Conventional analog TV requires whopping amounts of power for a given area (several hundred KW, or maybe even a MW or two!). On the other hand, a 100 Watt VHF/FM radio transciever with an excellent antenna design and location can cover the exact same area with voice-only communications, such as for a courier or taxi company. Now imagine if you could take the TV signal and put it into a very tight stream of ones and zeroes... it would still be more complex a signal than the voice one I mentioned, but much tighter and more cohesive than the big old analog TV signal. The outcome of years of testing and experience is that digital TV transmitters do not require anywhere near the sheer ooooomph of the old analog ones. The difference is startling at first, but when you see it with your own eyes you get it. The best examples are down in the U.S. where the power differential is quite striking, yet the area is similarly covered.
I'm not saying I'm happy with the numbers I'm seeing used in Canada, since I suspect the Canadian broadcasters, who often have stakes in satellite and cable TV services, have ulterior motives for keeping them low.
