Jake,
Have a look at the just released Linux Mint 10 as well. Impressive interface coming from Windows and the DVD version includes all necessary codecs.
- Stew
I just upgraded to Mint 10 on my T42 IBM laptop. The synaptic package of GoogleEarth crashes but to my surprise if you do a local home directory install of the latest generic linux release directly from Google it works really well...and this is with 32 meg assigned vid ram on an old radeon 7500 integrated chipset.
No spinning globe or usable flight simulator but the rest is really fast and stable for a change. But heck 64 meg on XP with an Nvidia Gforce 4 didn't even come close to what this install of GoogleEarth on Linux can do. The network load times are incredibly fast and the 3d map is good though a little slow to load. guess it just needs time to reallocate buffer space. But it does not crash Xorg at all anymore.
The one problem I had was getting my cell phone to send via bluetooth to the laptop. Turns out you have to install the gnome-user-share package which is not there by default.
After all the fiddlin' I have a beta of ps3 media server and Mediatomb streaming 5.1 dvds directly to my Samsung allshare through wifi with little to no drop. You have to edit the config file for Mediatomb to do this but it does work if you have the patience and the google skills.
There is no rt kernel option yet but you can bet it will be along shortly when the Ubuntu-Studio guys get it fine tuned for audio and video production. That said Audacity is current and seems to work better than in the past with pulse. Pulse does have an rt configuration option so when the rt kernel is released high bit rate recording in real time should now be much easier with the pulse server.
What I love is that both my onboard sound and a pcmcia audigy will work at the same time...something that was impossible with WindowsXP. Turns out that you can separate the onboard sound irq from the rest of the buss on this laptop. This makes realtime monitoring a breeze. Audacity will now pipe the monitor output to the onboard and take the input from the pcmcia at the same time and at last pulse can easily be configured to do this. That way the dsp on the audigy will do all the hard high bit rate a-d conversion work and leave the AC97 onboard very little work to do.
Of course you can install all the non-free coded stuff like libavcodec-52 and run Ubuntu the same way. It is just that the Mint distro has everything ready installed except inbound file acceptance for Gnome. Mint plays dvds right out of the box and if you put in the latest VLC you can do blueray....if you have a drive and the hardware to handle it.
I must say the video drivers in the latest Xorg are really getting good and will do most things without having to install an OpenGL driver. I guess they have really been working overtime to get things right.
