EDIT: UPDATE March 10, 2005
I finally got around to updating this post. Notably, I have changed the fix for vertical banding using the correct adjustments in the service menu.
I know that there may not be a huge number of 50v500A who browse and post here, but I am hoping to see some input from others on this thread.
Remember: service menu options should not be altered hap-hazardly. And it is possible for you to void your warranty by fiddling with it. You have been warned. When in doubt...don't bother fiddling with these things. FYI: I am NOT an expert, or a professional calibrator...but I enjoy doing things for myself when I can. But do not take my words as gold in terms of advice.
Its also a good idea to write down all service menu settings that you are conisdering changing before you change them. You will certainly forget the settings if you casually change them without paying attention to what they were to start with. I'm not taking responsibility for any problems encountered with your set because of suggestions posted here.
EDIT: Vertical Banding Fix:
1. Enter the service menu by putting the TV to a blank input and shutting it off. Then hold the input button ON THE SET while turning the power on (on the set works fine). You should see the service menu as the set warms up. Don't worry about the low quality appearance of the text...this is normal.
2. This LCD Drive menu has a 'STRIPE' for vertical banding and a 'STREAK' for horizontal banding (looks like ghosting). Select STRIPE and a test pattern will appear. There are actually ~15 patterns that correspond to low/mid/highlight levels on each colour chanel.
3. Cycle through all of the ~15 test screens and adjust the value up or down until VB is eliminated on each screen. Slight adjustment to any value produces either light (too high) or dark (too low) vertical banding. The goal, then, is to properly 'center' each value to eliminate all banding.
I adjusted mine...and the good news is that this completely eliminated any VB. The torture test was an undersea documentary with lots of blue and gray midtones and flat areas of colour. Zero VB (where I had very faint light bars before).
NOTE: I also left the VREF setting increased by 10% as it seems to improve contrast.
WHILE STILL IN THE SERVICE MENU, you can switch to a live input to see your results. DO NOT PRESS ANY OTHER BUTTONS ON YOUR HITACHI REMOTE WHILE AT THIS TIME because you can unwittingly change service menu options without knowing it.
-If you are happy with your setting, switch back to the blank input, and exit the service menu.
- Now you can go back to other inputs and fiddle with your user menu settings and re-calibrate.
OTHER NOTES:
1. turn off black enhancement. This crushes blacks and compromises detail. It also leads to noticable rapid changes in brightness that appear as flickering in parts of the image on some media.
2. Turn the sharpness control off. My hitachi needs no edge enhancement and produces a sharp image without it. Turning it on only removes detail around otherwise well-defined edges.
3. fix the red push in the user menu colour decoder section. I had to bring my red control to about 38%.
4. put the picture up as high as you like...the hitachi does not blow highlights with picture at 100% like some sets do (the panny LCD for example)...and does not suffer burn in or wear at 100%. Use the brighness control to set black level (bring it down as low as you can without losing details in the shadows). This will maximize contrast. I find that a setting of 45%-50% brightness and near 100% picture is very contrasty with lots of punch and no loss of details.
5. Turn off noise reduction...it removes detail, costs sharpness, and removes almost no video noise at all.
And, most importantly, post your comments and suggestions here so we can benefit from your experiences.
Cheers,
Mike
OTHER NOTES:
Cheers,
Mike
