Status
Not open for further replies.
741 - 760 of 775 Posts
Banned
I believe TVO is currently broadcasting at reduced power. Normally it booms in at almost 30 SNR but right now, it's down by half that amount at around 15 SNR here in Oakville. Must be because of RF safety with all the people currently working in the tower tonight.
Toronto TVO 19.1: I'm noticing that all of my tuners have trouble initializing connection with this station but once acquired it's a strong steady signal. I'm thinking it's the result of multi-path signals which the analog 19 always had in my area rendering the station unwatchable in my home. Anyone else experience this phenomena?
Yup signal is weak here also for 19.
Looks like TVOntario on channel 32 in Windsor is out for good. I can get 32.1 crystal clear with no issues but 32 analogue is all snow. Currently waiting for CBC to make the switch and I'll be keeping my eye on Radio-Canada down here to see if it goes digital or not. For some reason I havent been able to get any signal (analogue or digital) from CTV Two all day, will watch it also.
As discussed at http://www.digitalhome.ca/forum/showthread.php?t=107972&page=37 CIII-DT-32 converted many days ago and the analog signal is gone. As for the other stations, CBC should be switching momentarily while Radio-Canada (CBEFT) has switched from 54 to 35 earlier today. CHWI also converted last night.
The last time I tried (approx 11:00 am on the 31st), a scan got me 32.1 audio only. I could manually punch in 32.3 and get both picture and sound but it wouldn't stay in the memory and would have to be done manually again. Haven't tried the HD box yet but it looks like there is still a problem (at least for the two Sonys I tried).
I was able to get 26 from Belleville, barely. 480i however.
@wilspin - welcome to our 480i world down here in the Windsor area. TVO 32-3 has not been 1080i since it went digital on August 18th....bummer!!!
Thsanks OTAnut, luckily I have a choice if I swing aroud 180 it's 1080i from CN tower.
Is TVO the only station that is not announcing their call sign properly?
I compared the PAT table in their stream (using TSreader) with CBC seems the same but the TV does not identify them as TVO-xx in the channel display.
+1
None too pleased here with the continuing issues with CICO-DT 32 and even CICO-DT 33 from Chatham.
It's been two weeks now with the same problems remaining. Windsor's TVO only decodes [480i] on around half the tuners here, while TVO Chatham 1080i signal works great...that is.. when it works. Today and right at this moment all I'm getting is a black screen with good signal once again.
OK i do get 1080i here in London but now 18-1 TVO RF18 has 100% signal strength yet no picture on one of my three sets........
Two Sony TVs and one Samsung HD box, no picture on TVs, no signal on box. TVs do work on .3 but do not retain memory. Last checked 11:00 am Sept.01/11.
Status
