941 - 960 of 970 Posts
I've used the WinTV-HVR-2250, HDHR3 and HDHR4. For versatility and ease of use (less hassle), the HDHR line wins. For sensitivity, the HDHR4 wins. The HDHR Plus adds MPEG4 compression. A big win with the HDHR4 line is being able to place it anywhere, mine is close to where the RG6 enters the house for less line loss. Another is being able to access it from almost any PC, media player, tablet or smart TV. That means no need to run RG6 to the PC or anywhere else.
After thinking about it. I ordered the HDHR plus mostly so its easier on the network and if I want to records shows. Since I cannot find WinTV-HVR-2255 in Canada, and don't like surprises when I order from the US (or how long it takes), I went with what was available.
I think I will move all the equipment in the basement and call it a day.
Thanks for the feed back.
Well just sent the HDHR plus back to amazon. It was too much trouble to get to work on my PC (it did work). The biggest issue was the DLNA did not work properly on my blu-ray (sony). It detected it but I could not select a channel. Kinda disappointed on that one.
I'll probably pickup a usb tuner (or wait to see if I can get the HRV-2255) depending if I go through with installing an outside antenna.
Thanks for the help.
Is the WinTV-HVR-2255 capable of multi-rec? e.g. if the HDHomerun is tuned to an OTA channel that has subchannels (e.g. 33.1, 33.2) you can actually record them on one physical tuner at the same time.
I've recorded up to six programs at once on the HDHomerun, despite the fact that it has only two tuners.
Looks like no one here has had a chance to try out the 2255? I ordered one online at Canada Computers, and I'm just waiting to see how long it will take for them to deliver it.
There are some online reviews of the 2255, not on this forum, and they have been unimpressive in general - saying it's not much better, if any, than the previous model 2250. I have been using the 2250 for a couple years now, and it's performed very well for me.
Yep, I think its probably a case of people sticking to what is known. It'll be interesting to see how it does for you.
Hauppauge Win-HVR-2255 MINI Review:
This weekend, I received the new Hauppauge HVR-2255 tuner card and installed it into my Windows Media Center PC. I also have the previous generation 2250 card, so I kept both cards installed to perform a side-by-side comparison. The 2255 comes on a shorter PCI board than its predecessor, and close examination shows that Hauppauge has replaced the Samsung demodulator chips with LG Electronics "LG DT3306A".
The installation experience from Hauppauge is largely unchanged. Simply download newest drivers, install the bundled WinTV 8 software (optional), and run a channel scan. The 2255 takes noticeably longer to perform the channel scan. I would estimate the duration to be at least twice as long.
Both cards pulled in the same number of channels. All of the Toronto stations showed full signal strength (6 bars out of 6) in Windows Media Center - again for both 2250 and 2255. Where I noticed a subtle difference was on the more distant WUTV (Fox), where the 2250 only showed 3.5 bars of signal strength, but the 2255 was able to capture 4.5 bars of strength.
This leads me to believe that there is moderate improvement on the 2255, but not enough that I could pull in more distance channels than before. I have always found that WGRZ and WUTV to be the two weakest signals that my HTPC could pull in, so it will be good to see if the 2255 can receive them more reliably.
I'll spend some more time comparing signal strength over the next week or so, to confirm my findings.
Where did this discussion move to?
My WinTV-HVR-1250 is failing, curious what the current reigning champ of tuner cards is. I already have a 950Q & an HVR-2250, I'd like to buy something different.
Unless/until ATSC 2.0 and 3.0 are adopted, the state of the art ATSC tuner chipset has been at Generation 6 for many years. So, the computer-based tuner device manufacturers are really just adapting that chipset to different form factors as they have come up, such as PCI, PCIe, USB, etc. etc.
The only real issue is whether drivers exist for a desired tuner device on your OS, and more importantly whether a certain model or line is known by others for being buggy in some way.
So, no news is good news. ;)
I hear the new 955Q works really well. It uses an lgdt3306 demod. Which is a close cousin to the lgdt3305 demod, but more advanced. The lgdt3305 was used in the Aero-M, and in my LG LCD TV.
That's great to know that the 955Q is a good replacement because one of my 950Qs has gone a bit flakey lately after all its good service over the years! I'll look up the particulars.
stampeder,
I had a $50 gift card from Amazon sitting here since September, so I finally used it to grab a new 955Q. Balance was only like $26. it showed up in 2 days. I haven't opened it yet, but I will let ya know how it works for me when I do.
here is a comparison between the 955q and hdhomerun3.
stats from hdhomerun3 come from 905shmick's bash script. the 955q just manually tuning and taking notes.
That 955Q really does perform well.I just hooked it up to the outdoor antenna system and compared it's 'signal strength' and 'snr' to the hdhomerun. In particular,there is this one channel here,rf ch 38. which is always somewhat degraded snr wise,despite having a really strong signal. Note that RF 38 and RF 39 transmitters are on the same hill, about 1mi away from each other, with similar transmitter ERP and height.
I have always suspected RF 38 is experiencing some multipath degradation here. But have never got around to trying to find a better location on my property for the antenna to see if it made any difference.
The 955Q is the first USB tuner I have used which didn't seem to have that degradation on that specific channel. I will play around with azimuth later tonight,
to see if I can find an azimuth where the degradation is apparent on the 955Q
Also, the 955Q is the first USB tuner I have seen which is capable of reporting raw Signal Strength in dBm. Should be extremely helpful to folks understanding what's really going on while troubleshooting. All my testing is in linux, so I don't know what the Hauppauge Windows driver does at all. I should point out that the linux driver's counter for 'BER' reports nothing but all FFs (0xffffffff) on every signal. Something is in the
wood pile in that regard. So, I took a look at the driver's source code and played around with it in debug mode. Think I have a fix for that which
I have tested here. Seems more reasonable to me now, but with no documentation on the chip, there's really no real way to positively confirm.
Why I like open source software so much...when something inevitably doesn't work quite the way you like, at least you have the opportunity to change it:)
See pic...
the hdhomerun3 stats are on the left,955Q are the last 2 columns on the right. They seem to correlate quite well. Makes a believer out of me so far...
The HDHR3 is rather dated. The HDHR4 or HDHRC (HDHR5) will perform better. I'd like to see a comparison between those and the 955q.
sorry, I don't have anything newer than a hdhomerun3 and no plans to get anything newer. I am still unable to get the normally problematic rf ch 38 to fail at all here on any azimuth using the 955q.
@majortom
When you are using a USB tuner like the 955Q, what do you do for strain relief to ease the stress on the USB port if you are connected to the antenna with coax? Do you go through a USB hub or use an extension cable, or have you a way to fasten the cable to the chassis?
geode I used short USB cable extenders and stiff coax jumper cables to keep my 950Q sticks suspended in air. I think those sticks cool off better that way too because they tend to run pretty hot all the time.
exactly, I took a look at the Hauppauge website but noticed that nowhere does it mention the package contents. So I can understand the question. It comes with:
the device itself, a short (6" or so?) shielded USB jumper cable, a retractable omni antenna, an analog video/audio input/breakout cable and a remote.
Should also mention it's form/fit identical to the 950Q and comes with all the same accessories that the 950Q did.
