Some stands have cable management built into the supports/legs, etc. If not, then look for cable management on the web (ties, flexible conduit, etc). Note that you should not put signal cables (like HDMI) right next to power cables. An attempt should be made to have power cables intersect signal cables at 90 degrees and not run parallel right next to the signal cable.
The best thing is to let cables simply "Hang loosely" from where they go into the various devices. You could add a "cloth" or something similar that hangs off the back of the TV/stand to block your view of the cables which would then be behind the "cloth". The colour of the cloth would depend on your background. I used black.
