1 - 6 of 6 Posts
I can't seem to get the TV out function to work on the Vibrant. I bought a 3.5mm to RCA cable and enabled the TV out function in the settings menu. I've tried it on a couple TVs but all I get is a messed up screen. Has anyone had success with the TV out function?
The cable you would need for this has the 3.5mm jack on one end, and red/white/yellow (composite) connectors on the other (not just a straight 3.5mm-to-RCA cable.
i thought the galaxy s had a mini hdmi? or am i mistaken?
if its liek my omnia 2 (which uses the 3.5mm headphone jack) you need a special cable. i bought one online for 3 bucks labeled for a nokia and it works great.
detects it as a standard ntsc 480i picture and works fine other then that the colors of the cables were wrong. ( i think red / yellow were opposite, havent used it in a long time lol)
Discussion Starter · #6 ·
Oops, yeah I meant 3.5 to composite r/y/w. It's set to NTSC and I switched the cables around going into the TV. Does anyone have a link to that Nokia cable?
1 - 6 of 6 Posts
